Location of IAC on 91 Explorer XL - Ford Truck Enthusiasts Forums
Old 09-02-2003, 01:27 PM
creature66 creature66 is offline
creature66 is starting off with a positive reputation.
Just curious as to the location of the IAC on the 4.0 ohv, I have already cleaned the MAF sensor as per the directions on here and smoked my tires in 2wd out of my driveway (kudos to whoever discovered that little trick *grin*) but I'm not sure if the IAC is the black plastic box on the side of the throttle body or the aluminum tube type of thing that is just behind it on the side of the intake. I don't have a whole lot of experience with fuel injection systems. I was still playing with carb motors until I got my Exploder and I love my truck now. Any help finding this IAC thingy would be a great help. And if anyone has a set of automatic front hubs for sale for a 91 XL lemme know. Blew em first time in the mud, 4-wheelin rocks!
Old 09-02-2003, 05:10 PM
Dialtone Dialtone is offline
Dialtone is gaining momentum as a positive member of FTE.
The "black plastic box on throttle body" you referred to is the throttle position sensor. Rearward of that and mounted to the intake is the Idle Air control valve. It is mounted with 2- 8MM screws (i think, could be 10's though) If you still have the black plastic cover with 4.0L lettering covering the throttle area, it snaps around the IAC.
Hope this helps
Dialtone
Old 09-03-2003, 11:21 AM
Thumbs up Location of IAC on 91 Explorer XL
Awesome, thanks fer the help dude... I'm goin out to rip 'er apart now.
04 F-150 5.4L 3V IAC wisecountybuck Modular V8 (4.6L, 5.4L) 6 05-25-2010 10:21 AM
IAC on 2004 4.0 engine? dale88 Explorer, Sport Trac, Mountaineer & Aviator 7 01-07-2008 08:15 PM
pics wanted of IAC f150plow 1987 - 1996 F150 & Larger F-Series Trucks 5 12-03-2006 06:39 PM
Location of IAC on 2000 F150 5.4? Michael_DB 1997 - 2003 F150 2 08-11-2005 04:26 PM
F150 IAC valve location? 2fords 1987 - 1996 F150 & Larger F-Series Trucks 3 01-17-2002 11:08 AM
Tags
f150, iac, on91
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
