2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
AFE Pro Dry S air filter
Old 03-28-2017, 09:47 PM
Chadmokc's Avatar
Chadmokc
Chadmokc is offline
A quick review on the AFE Pro Dry S, stock replacement, drop-in filter for the '17 6.7 Powerstroke. Just got delivered tonight and I installed it. I carefully pulled the black foam off of the factory filter (its glued on) and also installed it in its secondary filter location to minimize dust into the air box.
I've ran the Pro Dry S (non oiled) filters on my last few trucks with great results. I took a quick run around the block and the engine feels a tad peppier from the increased airflow (it's just a filter, don't expect 10 more lbs. of boost) 😉 I've logged a lot of Powerstroke miles though and keep my stock filter to switch back to when I'm cleaning the AFE and the difference is noticeable. Also in my experience I usually pick up a .5 to 1 mpg avg. increase (I'll take what I can get) unless I'm hot rodding. I'll post back once I log some more miles. I ordered direct through AFE and although it shows out of stock online, they said it's because they are built to order and are in fact available.
They have 3 different style filters available. If you're truck stays mostly on-road then you don't technically need to reinstall the foam secondary but I am in dirty/dusty environments everyday and took the extra precaution. They also offer a more performance oriented Pro 5 R oiled filter designed for maximum airflow that the highway haulers would probably benefit from. Then for the extreme dust and offroad they have another filter with even higher filtration. Haha I sound like a rep! No affiliation. Lol.
Old 03-29-2017, 08:07 AM
luke0204's Avatar
luke0204
luke0204 is offline
Thanks for the report...look forward to updates.
Old 11-06-2017, 03:42 PM
wstout's Avatar
wstout
wstout is offline
Have you got any codes from using this filter? Any updates on gas mileage?
Old 11-06-2017, 08:42 PM
brandontolentino's Avatar
brandontolentino
brandontolentino is offline
Have you ever done oil analysis between the stock and AFE filter?
Old 02-01-2020, 04:47 PM
F TOO FITTY's Avatar
F TOO FITTY
F TOO FITTY is offline
sure, I'll bring this 2 year old thread back from the dead!
I also have a Pro Dry S, but didn't put the foam block back in that was glued to the stock filter. Now i'm thinking maybe I should. Anyone have an opinion on that?
Thanks
ps - i see that K&N now makes a replacement foam block for this purpose... https://www.knfilters.com/85-2003-ai...er-foam-insert
but I think for $25 i can re-use the one from the stock filter...
Old 02-01-2020, 06:35 PM
AKDV's Avatar
AKDV
AKDV is offline
I didn't reuse the foam block when I installed mine.
Bohen
6.7L Power Stroke Diesel
07-30-2019 07:06 PM
jmtbiggin
Large Truck
01-26-2019 01:50 PM
richdawg
77
09-17-2014 05:12 PM
snaponprofile
Ford Truck Parts for Sale
03-09-2012 07:31 AM
SGnAZ
1999 to 2016 Super Duty
11-23-2008 09:41 AM
Quick Reply: AFE Pro Dry S air filter
