1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Cigarette Lighter Removal on 2000 F250 Super Duty
Old 03-28-2017, 09:41 PM
67 FE Fan's Avatar
67 FE Fan
67 FE Fan is offline
If you need to remove the cigarette lighter receptacle (not the powerpoint plug) on a 2000 Super Duty, follow these steps: Remove the hook panel on the lower dash next to the lighter (two bolts). Unplug the wire in the back on the lighter (squeeze one tab). Reach behind the lighter receptacle and angle it slightly downward and push towards the rear of the truck. The lighter will pop out. FYI-the lighter receptacle itself has two tabs on the black collar holding it in the dash. Not sure what other model years this style covers.
Old 03-29-2017, 10:41 AM
r2millers's Avatar
r2millers
r2millers is offline
Thanks for sharing. Curious why you would want to remove it? Another power port for accessories, USB ports, etc.
Old 03-29-2017, 10:48 PM
10frank10's Avatar
10frank10
10frank10 is offline
Also curious about why you'd remove it. What did you add in its place?
Old 04-01-2017, 01:07 PM
67 FE Fan's Avatar
67 FE Fan
The mobile phone charger was not charging through the cigarette lighter socket although the light on the charger was lit. I tried the charger in the powerpoint receptacle and the phone charged properly. I changed out the cigarette lighter socket and the phone is charging properly now.
By the way, the lighter socket was less expensive at the Ford dealer (around $11) than on Amazon. Go figure!
Old 04-01-2017, 02:45 PM
ligito's Avatar
ligito
ligito is offline
I had difficulty removing mine and replaced it with another power ports. though.
Old 04-02-2017, 07:09 AM
sur48's Avatar
sur48
sur48 is offline
Funny I saw this thread. My power point plug went bad but still showed that it was working when I plugged in a cell phone charger it drove me crazy. My pc charger did not work for a month before I just took a chance and replaced the cigarette lighter power point. So my ford parts guy sells me { 11 bucks}a insert only. So i had to unplug and remove power point from dash. Then had to trim existing harness plug emboss groove on plug to aloud proper insertion. Then had to open up the hole the sleeve cigarette inserts into and to my surprise it worked i am happy but there has to be a better way.
Old 04-02-2017, 10:41 AM
Yama4fitty's Avatar
Yama4fitty
Yama4fitty is offline
Hey there Bob
I removed mine to add this...
My new head unit did not have an auxiliary port so I did this instead of drilling holes in the dash. The USB port and auxiliary port connect to the radio so I can charge stuff and play music from a USB drive.
Plus I don't smoke
Old 04-02-2017, 10:48 AM
sur48's Avatar
sur48
sur48 is offline
Originally Posted by Yama4fitty
Hey there Bob
Plus I don't smoke
thats what I asked for my ford dealer parts guy said didnt exist . cool may be I will put in lower cig lighter. the power point has a larger fuse fro my pc charger. thanks
Old 04-02-2017, 10:53 AM
Yama4fitty's Avatar
Yama4fitty
FYI, it is not a Ford part. I got it off Amazon and should have posted that in my original post. Here is the link to it...
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
There are others like it too that have dual USB's if you do not want the aux port.
Old 04-02-2017, 11:15 AM
sur48's Avatar
sur48
sur48 is offline
thanks for the link . I figured it was not a Ford I was going to try Professor Googel or ebay
Old 04-02-2017, 08:32 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
I added one of the usb/aux plugs a year ago. I LOVE IT
Old 04-03-2017, 07:01 PM
ligito's Avatar
ligito
ligito is offline
I have one of those that I got at an auto stereo store.
Old 06-13-2017, 01:06 PM
MattE303's Avatar
MattE303
MattE303 is offline
I am intrigued by the usb/aux plug that Yama4fitty linked, but I'm using the stock stereo (with an adaptor module that converts the CD changer into an aux port), so I don't have a USB connection to plug it into. Has anybody wired this plug's USB port to the cigar lighter wiring (with some sort 12v to 5v converter) so it could be used as a power port for phones and such?
67 FE Fan
03-29-2017 07:42 AM
beemr
12-31-2015 03:15 PM
Mick83
Modular V10 (6.8l)
12-27-2015 03:13 PM
2011F250Lariat
01-19-2013 06:14 PM
tarinitup73
06-18-2011 08:05 AM
Quick Reply: Cigarette Lighter Removal on 2000 F250 Super Duty
