Front disc brake engineering question
This may be a really dumb question, but what keeps the front pads off the front rotors when the pedal is released? I just replaced those pads, along with new rotors and bearings in my 93 and I couldn't readily see any counter force to the hydraulics in the system. It's obvious on the the rear, what with all those damn springs, but not on the front. For reference my setup is the rail slider front disc.
Nothing, same as every other disk brake setup. The disadvantage is that there is slightly more drag in disk brakes than there is in drums. The advantage is that the pads wipe the disks clean so you don't get the exciting feeling of no brakes for the first few yards when you apply drum brakes after driving through a puddle.
(disks have other advantages too, that aren't related to the fact that the pads stay against the rotors)
I had the same problem with mine where one side would pull much harder then the other (and sometimes take longer to release) and it turned out to be the hose was collapsing, which didn't let the fluid come back quick enough when letting off the brake
2011BlackBeauty
6.7L Power Stroke Diesel
01-05-2014 01:50 PM
JohnPeter
03-12-2009 02:52 PM
lukedraper
1978 - 1996 Big Bronco
10-23-2005 11:18 AM
