Transmission builder recommended Synthetic 10W30 in ZF6
Old 03-28-2017, 03:37 PM
beef tits's Avatar
beef tits
beef tits is offline
I just had my transmission gone through by a seemingly reputable shop. They only do manual transmissions and they came recommended by a local Powerstroke tune shop.
They took the time to put IN WRITING that they recommend using 10W30 full synthetic in my ZF6. He proclaimed that ATF is too thin.
Being that they put it in writing and are warranting their work... I am inclined to try this but I wanted to run it past you guys... Has anyone ever heard of this?
Old 03-28-2017, 03:50 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
No, but I would run what they tell you till the warranty is out. By then you should no.
Old 03-28-2017, 07:08 PM
cookie88's Avatar
cookie88
cookie88 is offline
Seems like it would be worth a shot. Especially with a warranty. Care to be our Guinea pig?
Old 03-28-2017, 07:17 PM
pirschwagon's Avatar
pirschwagon
pirschwagon is offline
I would recommend any GL5 rated multi viscosity 75/90. In SEVERE duty, used predominantly (> 75%) for towing I would use the 75/140.
ATF is designed for Automatic Transmissions. Different from a Gear Mesh Transmission.
See what Amzoil and others say in their testing data. I have no idea other than what I do for AT and MT.
Old 03-29-2017, 08:32 AM
Fat Diesel's Avatar
Fat Diesel
Fat Diesel is offline
I've been using Syn ATF for 18 years. No reason to change now.
Old 03-29-2017, 10:59 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
Hey pirch, these granny are not a "bath" type slushbox. There's a pump in there. No way would I run that thick of crap. I'm with FATS, but I run conventional mercV
Old 03-29-2017, 11:51 AM
BBslider001's Avatar
BBslider001
BBslider001 is offline
This says a lot. I had no idea. Thanks for the info!
Old 03-29-2017, 12:36 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Pirsch, I think ya misread? He's talking about motor oil in the transmission, not motor oil or ATF for the diff.
Stewart
Old 03-29-2017, 01:46 PM
Dirtscooter250's Avatar
Dirtscooter250
Dirtscooter250 is offline
I would never run anything other than ATF in the ZF6 since it has an internal pump and cf synchros.
Old 03-29-2017, 07:33 PM
beef tits's Avatar
beef tits
Picked it up today. I had them fill it with the synthetic 10w30. I'm on a new clutch so am taking it easy for the break in period however the truck shifts a lot better.
I also have no good reference for shifting because up until today, I have only driven it with a transmission that was half full of coolant.
I'll update as I drive it along...
Old 04-03-2017, 02:54 PM
beef tits's Avatar
beef tits
One week and 400 miles later... still shifts great. I'll update again once I have a trans temp sensor working and run that for a while.
Pocono Super Duty
Modular V10 (6.8l)
41
01-13-2014 08:58 AM
TheACguy
08-02-2007 08:22 PM
stbrem
1999 to 2016 Super Duty
03-26-2007 05:06 PM
kaufman_sm
Modular V8 (4.6L, 5.4L)
09-04-2003 06:21 PM
Jim McCarty
Oil & Lubrication
11-11-2002 10:53 AM
Quick Reply: Transmission builder recommended Synthetic 10W30 in ZF6
