Anyone have rust & cracking in their 4x4 front spring buckets?
I was disappointed to see the tops of my front coil spring buckets to have cracks in them. Then I start picking and pieces of rust start flaking off about 3/32" thick. This truck is well taken care of, maybe a dozen times in snow ever. It's a 2005 F250 SD X-cab long bed 4x4. The only other rust issue I have is a small spot on one of the bed supports. Is this a problem with these trucks? I wonder how long it will be until the coil top pops through and takes out other components under the hood? I just cannot believe this. Had the truck been riddled with rust I might understand. I wonder if fatigue opened up the crack and water found it's way there and initiated the rusting? Go 1/2" below the top and it's shiny black paint. You would have thought I waxed it.
Yeah, same truck, used for plowing, same concerns. 55K miles. Good truck in many ways, but rust resistant it ain't. My bed is rusting out over the wheel wells, I've replaced rusted out tranny cooler lines, power steering lines, shocks that pretty much fell off, trailer hitch, cab steps, rear brake backing plates, every single part of the front end steering components - hell, even the front drive shaft was so weakened from rust it exploded one night while plowing. Sometimes I wonder if I'm going to make it home.
Better to replace them now than to wait until something happens.
With all the salt and chemicals they use on the roads now days, I'm surprised any vehicle does as well as they do. Everything is thinner and stamped out of lesser grade materials. The only thing that can be done to prevent it from happening is weekly washing and then undercoating and painting the metal components every year or two.
Krown or Corrosion Free. I have Krown. No experience with the other but read up on it. It's supposed to be better than Krown. My 2011 shows no additional rust since I had it done at 2 years old. You CAN NOT drive these expensive trucks in salt OR live in a damp climate and not apply some form of rust proofing. Steer clear of the black tar-like undercoating process. The factory does nothing to protect against rust. I wish Henry would put a winterization or rust belt option on the list. Have Krown done from day one. I also installed the Ford rear wheel well liners. These liners would be part of the above-mentioned salt belt option. I understand selling trucks. I don't understand a 60K truck crumbling in 5-6 years. Thus the need for rust proofing. I looked into a sacrificial anode system too. That's not a bad idea either.
The best option IMO is to move to Phoenix. These guys have it good. Their trucks look new at 20 years old.
