2015 6.7 POWERSTROKE INTERMITTENT NO BOOST
Having a intermittent no boost issue. Running down road usually pulling fifth wheel trailer, then notice low boost 5 to 7 psi. No check engine light, nothing. Its done it 5 or 6 times. If I hit clear code even truck has no codes set with ez-link while drive boom boost is back. Or if I pull over cycle key boost is back. I do have ppei tunes, truck is stock no mods. I have had it happen with tow tune or pull tunes out.
Take the tuner out.
Then run it. If there is an issue the check engine light should come on, or codes should be set.
Just because the boost is low does not always mean then is an issue, even with towing if you are at speed and there is not a power demand.
When this low boost concern is noted, what is your fuel consumption on the current mpg graph?
Also when I mean it has no boost I mean you hold it on the floor and it will not build more than 6 or 7 psi. One thing also is if I'm towing with engine brake on, I notice you the engine brake light on the dash goes off, and I can't turn it on and then I know truck won't build boost. cycle key and everything comes back.
No boost update was issue discovered?
Exact same issue on 2016
I started a new thread and finally found someone else having my issue. Mine is low boost. Truck will boost up to about 18 psi max. Builds slow on take off. Stop, turn truck off about half the time it’s there, half the time it goes away. 85000 miles. Good maint, all Ford filters. Never tuned. Never even been under the hood except maint. Any resolve here????
I’ll try to keep this as short as possible
Mine was cured this weekend by a DEF tank heater. Cleared the code she runs like a scalded ape again. Before changing the heater I would start the truck. Let it idle. Clear the “Pending” heater code and truck would run fine even though the permanent heater code was still there. It apparently checks randomly because it did it a few times in the middle of driving. It derated itself, check codes, the pending heater code is back, clear code- truck runs great. I did this many times to make sure it was the problem. I suppose the engineers do this to irritate you enough to get it fixed. Because it’s 100 degrees in Texas right now. I also think it’s defueling when it does this, which causes lower boost. I don’t think it’s a low boost issue on its own. It’s done this randomly long before the CEL came on. I didn’t have a dongle back then but suspect something was happening and I just didn’t know it. Without a cel I would recommend starting with a defuel problem.
Same issues- i fixed it
mine was the connector.
kept thinking the turbo was stuck open. but the solenoid that controls it was actually unplugged. no boost, 1 or 2 lbs, black smoke, no wastegate. now power, kept happening every couple months…. no codes (fully deleted, egr,pdf w/ h&s)
i just had the same problem. turns out the connector was bad, one of the keeper ears broke and caused the plug to barely connect.
was having intermediate boost.. then fixes itself…then no boost…randomly (usually after running 85 for a couple hours it would happen)
finally the connector came off completely.
can’t see the plug-in. but no need to pull the manifold. just a mirror and a light you can replace the pigtail and plug it in.
hope this helps!
