Hard Steering Issue
Hard Steering Issue
For the last year or so my truck had been giving up some hard steering issues. Sometimes it seems as though the steering wheel has to be turned excessively before the wheels move. Everything as far tie rod ends and balljoints have been replaced recently.
The steering does have excessive play in it.
Doe these trucks have a rag joint or U joint in the steering shaft?
Do the steering shafts wear out and cause issues like this?
I thing it is the steering gear box itself. I havent diagnosed it yet. I trying to see what I should look out for when diagnosing.
Thank you in advance for any and all replies.
Yes it will have a rag joint unless someone changed it. My 94 does. Don't know if the steering shaft would cause it unless it is really bad. Steering gear box will cause play,excess travel. Also I have read where the steering column bearings will cause excess play. I had to put on a rebuilt steer box because of excess play. Hope this helps.
Sounds a lot like steering gear box but checking will confirm. FYI Red Head steering box seams to be the go to . I used a napa rebuilt for 1/2 the price and life time warranty. It has worked well for 2 yr or so now. If you need a new steering shaft you can get them on e-bay for about 300. has u-joints in lieu if rag joints.
Rachel Moody
15
01-16-2017 11:51 AM
fordbeast_80
12-28-2009 12:32 PM
Methodical_1
1997-2006 Expedition & Navigator
02-06-2009 07:22 PM
