7.3l powerstroke Abnormal readings at data link connector
Old 03-26-2017, 10:54 PM
HughLee's Avatar
HughLee
HughLee is offline
I have a 2001 F250 super duty 7.3l. I have a problem with engine loping at start up, smooths out to rough idle with momentary throttle advance. Then it has low power, runs rough/misses on trying to drive. CEL comes on after start up and while running, CEL off KOEO. Can't get my ACTRON CP9125 O.B.D.2 PocketScan to link,displays " no link ". Went to three different parts supply stores and they tried their scanners. First two were small and they said had no codes or said they couldn't pull them. OReillys scanned with a Bosch scanner and got "no link". He suggested blown fuse at cig, pin 16 of DLC. Fuses were good. Further testing of DLC using your, FTE forum article with Payson' s OBD 2 data link... jpg produced the following results: abnormalreadings at data link connector. Pin 2,4,5,10,13 and 16 were correct for both key states as described in article. Pin 7 however is way off. Where keyoff voltage should be 1.5 volts a Fluke DVM reads 5.38 volts. When checking pin 7 KOEO voltage should be 4.0 volts but I measure 8.1 volts. I believe this maybe why the scanners isn't linking. I can't troubleshoot without codes. Visual inspection of I.C.P. Sensor indicates oil leakage with oil into the connector. Disconnecting sensor doesn't fix problem. Engine starts/runs the same. I ordered new I.C.P and pigtail today but don't think that will fix my problem. I can hope, but I still need to get my data link connector repaired so I can pull DTC' s for proper diagnosis. We pull our" live in" fifth wheel and need to repair asap. Any help would be greatly appreciated.
Old 03-27-2017, 07:08 PM
DieselDenny's Avatar
DieselDenny
DieselDenny is offline
Do you have power to your cig lighter and/or power-port?
Just an idea but bumping this since no one responded.
Wondering........
Denny
Old 03-27-2017, 07:22 PM
HughLee's Avatar
HughLee
HughLee is offline
checked fuse first
As stated, I checked fuse at O'REILLY's when first trying to get scan. It was good, cig lighter working.
I went home to further troubleshoot the "no link" condition. Found what appears to be abnormal readings at DOC.
Old 03-27-2017, 09:00 PM
HughLee's Avatar
HughLee
HughLee is offline
last sentence should be 'Found what appears to be abnormal readings at DLC'. Additionally, pin 16 of Data Link Connector measures a constant 12 volts.
finallyo3gt
17
11-14-2015 10:43 PM
frustrated mechanic
2004 - 2008 F150
06-05-2015 09:45 PM
2004F250superduty4X4
1999 to 2016 Super Duty
05-28-2012 04:28 PM
mrwrench
10-11-2011 01:30 PM
canarycary
15
04-08-2004 10:59 PM
Quick Reply: 7.3l powerstroke Abnormal readings at data link connector
