2 rocker arms came off the pushrods what the hell caused that
89 I-6 had almost no compression in 2 and 3 cylinder so i started tearing it down for a valve job,when i got the valve cover off number 2 and 3 intake valve rockers were off the pushrods.they are bent also.i just got this truck and it ws this way when i got it.i wonder what caused this ,you think someone has overevved this thing or the valve springs are too weak.i think the push rods were jammed up binding the valves open.i took the bolt loose and removed the pushrods and did a compression and compression was 150 to 180 on all cylinders but number 3 is a little low maybe close to 120 but im using a push in compression tester thats unreliable.im thinking maybe it was ran a long time with the cylinders not firing and the valves are sticking from being carboned up
mnkeeking
05-07-2012 08:50 AM
robwymer
17
03-04-2009 02:22 AM
seizure911
05-23-2005 11:09 PM
84F1506
12-29-2002 02:45 PM
