1950 F-2 Restoration
I'm missing the cross braces for the bed. They must have been taken out by the shop it was at for a while since they are the ones that did the sand blasting on that part. If anybody has pictures of what they look like, or at least some kind of measurement for how it sits in relation to the frame of the truck I can make something that will work.
I should've known that... I have a bed floor kit from LMC floating around here someplace. Not sure, but I doubt it would have come with the cross braces? If somebody could just tell me where it sits in relation to the frame at various points, I could put in metal bracing and then just put a thin rubber isolator between the bed and the frame.
Unless you are talking about something more than a regular cartridge style respirator? Can you point me in the right direction to do a little more research on the topic in order to get up to speed with what is current now a days?
Thanks Scotty! I like what you did, I'll probably go that route. It looks like you notched the two in order to clear the hump in the frame?
There is talk of using this truck as a truck once it is done. My mom wants to drive it regularly, and we have talked of putting logos on and using it on the farm for certain things such as going to market.
#28
Now, there is significant cancer on some of the parts, bad enough that large portions will likely disappear when I try and sandblast them. Probably why dad hadn't sandblasted and painted them yet. What are my options here? I could probably blast them anyway, and hope the general shape is retained enough then fiberglass them. How do all these parts install on the truck? I can figure out the inside of the cab stuff easy enough, but the other stuff I don't know about...
Rust removal by electrolysis
I'd do just about anything to avoid media blasting parts. If I had a big enough tub, I'd even do body panels this way.
#29
I would never sand blast small, thin parts. I'd use electrolysis, instead.
https://www.youtube.com/watch?v=qi8qIxK4IlA
Big problem... how do you dispose of the solution once you are done?
#30
That's cool, I like the idea. However what tells you when it has been long enough and the part is ready? Is too long going to hurt? Too little time and allows rust to come back from underneath whatever you coated it with to resurface years later?
The best thing about this process is that the rust doesn't just go away; the part's surface molecules are also changed electrically to repel oxygen molecules, which are what foster rust formation due to the ionic bias.
The solution after you're done is utterly inert. It's literally water, bicarbonate soda and iron oxide. All that stuff occurs naturally and can go down the drain or even thrown on the ground. If you are worried about it's alkyd properties, put some vinegar in it until it quits foaming.
Note: you ARE going to produce some hydrogen gas during the process, so maybe next to your water heater or near other open flames might not be the best place to do this.
