2011 F350: Blower works but air not coming out of vents
I don't have hardly any air coming out of any of the vents on my 2011 F350, regardless of how the AC or heater is set. For what it's worth I have manual controls and I do not have dual climate control. This is an XLT crew cab with the 6.2.
What route does the air flow take in general? Does the air flow through the evaporator even if you're using the heater rather than the air conditioner? If so I suppose it's quite likely that my evaporator is just plugged up.
If not though, I would think there is likely something else wrong. I saw a youtube video on how to replace a blend door on an F250 so I wonder if that door could have anything to do with my issues? I would think if it were that door it would only blow out of one place rather than having barely any airflow no matter how it was set.
Any thoughts would be appreciated.
Thanks!
Thanks!
On my 2011 F350, I always use the manual mode and it generally won't blow much air until the engine gets warm enough to blow warm air (heater on in winter if course), even if I turn the blower to high. Once you've run the truck for, say, 20 minutes, do you still have the problem?
Without AC on warm days though, it gets pretty unbearable in there pretty quick.
Check out this thread - towards the end he explains how he fixed it by cleaning crap out....hopefully it's that simple for you
https://www.ford-trucks.com/forums/1...vac-vents.html
90F250351
08-31-2007 12:45 PM
jimbo beam
11-02-2006 11:30 AM
