1987 Ranger Cruise
1987 Ranger Cruise
Had a problem going down road, brakes applied all by them selves, their was no give in break pedal, had to pull over, turned off, let sit for a half hour or so while trying to figure out what was going on, didn't find anything except hot hubs, started back up everything is good again, suspect the cruise control. I was messing with it earlier in the drive, about 20 min before it happen, pressed a few buttons, it does not work, anyone know how to test. I know don't press any more buttons, LOL!
Yes it was the brakes, felt rims around lugs , they where hot, brake dust was all over front rims, just washed day before. Brake pedal was very firm , would not move. Later, I found a hose coming from cruise servo with plunger, at top of my brake pedal arm. Does this apply the brakes. It isn't normally touching anything, their is a slight gap from brake arm.
Remove the Master cylinder and checked Booster push rod, way to long, 1.35, adjusted in to 1.0, any longer and I would have to draw in master cylinder to mate surfaces. 1.0 seams to be the perfect length to wear the Master cylinder mates up with Booster with no effort, pedal and brakes are fine now, problem fixed. Thanks for advice!
Marine5811
05-19-2011 10:11 AM
mikebon08
08-12-2005 01:17 PM
NDS
04-04-2003 11:28 PM
