04 6.0 excursion dies while driving
My excursion died while driving down the road I lose everything but once I turn the key off and turn it back on it will start turning over again but don't . I let it set for a few minutes and it will start right back up like nothing every happen . In need of help this is our only transportation for now. The recent things I've done is change out the radiator and upper and lower hoses due to a tiny crack in the neck. I also changed out the hose from turbo to pipe on the hot side due to wear out hole. Please help
Welcome to FTE!
You're going to want to get a live data monitor like TorquePro or Forscan and bluetooth obd2 adapter. It's basically a requirement if you own a 6.0. There's a bunch of things that it could be, but without the data best we can do is guess.
You can try to pull the icp connector and see if it'll stay running. On late builds its on the passenger side valve cover towards the front. On early builds its in the back driver's side just behind the turbo.
Welcome to FTE!
If it quits dying then it's the sensor or wiring. The plug should be oil free. If there's oil, the sensor and pigtail need to be replaced. The pcm will use a default value with it unplugged.
I left it out for a quick drive and it stayed running but the I went for a longer drive and it died again but I drove it again today and it didn't die now I'm at a lost again now what should I try should I go ahead and replace the wiring and the ICP
In the meantime you could always make sure the batteries connections and frame/block grounds are clean and tight. I would also charge them all the way and have them load tested individually. Then check alternator output to make sure the charging & starting system is up to par. That'll rule out another possible problem.
That can help direct us to an answer if we pursue an actual issues with low pressure in the high-pressure oil system. You have a late model 04.
Greg has posted up the path to resolution of this - get a scan tool where we can see engine readings:
ICP pressure
ICP volts
IPR% duty cycle
If you do have low pressure in that system, it could very well be leaking dummy plugs (early 04's don't have dummy plugs), or it could be the IPR valve. Hopefully it does not turn out to be the pump. Get the readings first though, we don't even know if it is with the high pressure oil system.
Another thing to watch is FICM volts (MPower, VPower, and LPower readings). Get these readings KOEO, cranking, and at idle.
Plenty of good phone apps out there for getting readings (Torque, Forscan, Dashboss, etc). You will need an adapter for the OBDII port, but this is the cheapest way to go. Some people get the ScangaugeII also.
ICP pressure
ICP volts
IPR% duty cycle
That can help direct us to an answer if we pursue an issue with actual issues with low pressure in the high-pressure oil system. You have a late model 04.
ICP pressure
ICP volts
IPR% duty cycle
ICP pressure
ICP volts
IPR% duty cycle
