'61 Econoline
Old 03-23-2017, 02:09 AM
Doug Wyrwich's Avatar
Doug Wyrwich
Doug Wyrwich is offline
'61 Econoline
I want to replace the 4 banger with a V-6 capable of AC and more HP. Suggestions on a replacement motor please?
Old 03-23-2017, 05:45 AM
Wolfster's Avatar
Wolfster
Wolfster is offline
How do you have a 4 cyl in it? This would mean you'll more than likely have a 4 cyl transmission.
You could always look for a v-6 engine/tranny combo out of a ford ranger I suppose. Either way, you've got a lot of work ahead of you.
Another thing to consider is a 300 i6 engine/tranny combo. You'd be able to use a large six crossmember stock though you would need to get a pair of crossmember mount hangers.
Old 03-23-2017, 11:34 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
No Econoline of any year came with a 4 cylinder engine. 1961 Econoline available with the 144 or 170 OHV I-6.
Old 03-23-2017, 04:30 PM
EmilBarnabas's Avatar
EmilBarnabas
EmilBarnabas is offline
Your 1961 Econilne probably came with a 144 straight six. Many were replaced over time with a 170 or a 200. If you do not have a 200, that is what I recommend. It is an easy bolt-in replacement for the 144 and 170.
The V6 is a wide engine, so you will have problems squeezing it in between the seats. A well-built 200 should be cheaper and more powerful than any V6.
Old 05-03-2017, 10:38 PM
boxdin's Avatar
boxdin
boxdin is offline
A cousin of the 170 straight six is the legendary 300 Cu in 6 or 4.9 ltr in EFI form will bolt in your van easily. The EFI version in my van has 280 ft lbs torque which is more than most v8.
Old 05-04-2017, 07:19 AM
Wolfster's Avatar
Wolfster
Wolfster is offline
The 300 will need the large 6 cross member and support hangers welded to the frame. Also another transmission, driveshaft, and you'll probably need a 9" rear end to handle the torque.
Vinford
03-26-2014 03:26 AM
64fordf100
09-29-2008 03:31 AM
javi2001
Engine Swaps
10-10-2005 08:36 PM
brider
02-28-2005 05:45 PM
83blackthunder
12-14-2004 07:19 PM
Quick Reply: '61 Econoline
