Hey I'm just wondering if anyone has converted there 2003 or 2004 f350 with leaf spring front end to the 2005-2007 f350 coil front end is it possible? Thanks
An axle, steering gear, coil springs, spring buckets, and radius arms and mounts. I don't see why not. I think I have seen it done on another site. I don't recall seeing it around the 6.0 forum. The parts are available for example the spring buckets....
Oh and too add, you may as well swap the rear axle out too.If I remember right, In 2005 along with coil spring front, they changed the lug pattern so you would need the wheels too.
Aren't 99+ Superdutys all 8x170? At least non dullays?
