96 ranger heater/ac blower only works when warm out.
When i had this problem on my 87 it was a flaky connection at the connector under the hood. Removed it, from the blower motor plugged it back and never had another problem.
Try that and try wiggling the wires under the hood and dash.
And try giving the blower motor a good dope slap with your Ford wrench
I'd check on worn brushes and oilite bushings/bearings that are gummy. If the brushes go, there'll be less amps to create magnetic force contra the permanent magnets field. Increased temperature may allow the brushes to extend against the armature a little better, and conduct a bit better. Of course it could be the switch, the resistor pack, or the wires & connectors involved. Sometimes just disconnecting and re-seating connectors will make them work better.
tom
tom
centrix
07-26-2016 05:32 PM
coleboy11
1983 - 2012 Ranger & B-Series
03-25-2014 08:30 AM
raidersiowa
10-04-2003 06:32 PM
