KP, I see you used the stainless steel brake tube clamps, did you use self tapping or bolts and nuts? Got a pic of the other side? I like your reservoirs for easy access opposed to the spring tension ones. I'm concerned for the spring loaded caps and how easy they will be to remove from underneath the floor.
