Help with Dana 60 rebuild
Old 03-22-2017, 05:00 PM
jonnyrodder's Avatar
jonnyrodder
jonnyrodder is offline
Hello
This is my first time on here so I'm hoping someone can help me. I have a 2WD 68 F250 camper special with a Dana 60 under it. The bearings are packed and installed. I put the inner nut on, torque it to 50lbs to set the bearings and then back it off and tighten by hand. Then I add the lock washer (tab In the groove). I then add the outer nut and tighten by hand. Then bend in (2) of the tabs on the lock washer over the inner nut. Next I set my torque wrench to 160lbs and start to torque the outer nut. I get up to around 70lbs on the wrench and everything starts to turn and the tab on the lock washer shears off. This has happened twice now. Can someone please shine a little light on this for me? Thank you!
banicman
01-06-2013 11:04 AM
tractoman
02-27-2007 12:40 PM
Jmudder79
Offroad & 4x4
20
06-05-2006 01:57 PM
69crewcab
05-10-2004 09:36 AM
Quick Reply: Help with Dana 60 rebuild
