transmission
Old 03-21-2017, 02:21 PM
KingProvince's Avatar
KingProvince
KingProvince is offline
transmission
My 87f250 4x4 has the 4 speed +overdrive transmission and I was driving it yesterday to my friends house fine and dandy we went offroading then on the drive home it won't go into overdrive wats the problem I need help don't want to have to get a new tranny cause if I do I'm going over to a stick
Old 03-21-2017, 02:24 PM
andym's Avatar
andym
andym is offline
First we need to know what transmission you have. Ford didn't put a 4 speed automatic in trucks until a year or two after yours.
How many miles?
Any other recent work done to it?
Any history of transmission problems in the past?
Is it possible that your transfer case is stuck in low range? You wouldn't be the first to make that mistake.
Old 03-22-2017, 08:45 AM
KingProvince
correction
I just did a slow take off and it only goes into 2 gears no it's not in 4l I just rebuilt the t case and have still been using the diff ranges since it happened idk what tranny it is exactly but it's the 14 bolt pan
Old 03-22-2017, 08:46 AM
KingProvince
Old 03-22-2017, 11:53 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
Must be a light duty F250 to have an AOD behind it. 5L engine?
reamer
01-05-2014 08:20 PM
small.block.ford.guy
11-06-2013 08:34 AM
kregalmach1
12-27-2011 01:35 PM
kalsc
08-14-2006 11:58 PM
DECass
06-12-2005 11:03 PM
Quick Reply: transmission
