Motor diesels when you turn it off, where should I look?
So I've had a problem child 347 stroker in my '82 F150, and most of the problems are fixed except for a bit of a hard start and dieseling on shut down. What could make the engine surge after turning the ignition off? I've never had a vehicle do this, so I'm not really sure where to even start
Yea, I'd think 16 is too much. It could still be pinging just right on the edge where you won't hear it. You haven't mentioned cam specs, but with a manual trans it could idle slower. My 331 idles at 500 rpms with a Z303 cam (.587 lift, 228* @ .050 with a 112* LSA.) And that's with three 2 bbl carbs available adding fuel air, although the end carbs are dialed all the way shut, even so they'll still add a tiny amount of fuel air at idle. What's your compression ratio ?
So for engine specs, I've got trick flow 170 heads with 61cc chambers, probe/scat rotating assembly with -13cc pistons, Camshaft is comp came Hydraulic Flat Tappet 250/260, Lift .460/.474, edlebrock 600 cfm carb and one of their performer intakes, stock ignition. From what the kit says when I bought the rotating assembly I should be at 9.52:1, but I'm not totally sure I believe it. I wish the engine shop had done the calculations for me, since I don't know deck heights and stuff to do the calculations on my own. I'll dial back the timing today and see what happens though.
Update: I"ve backed the timing down to 11*, and it still runs on. I've brought the idle down to where it sounds like its gonna stall when i let off the gas and it still does it. Not as much as it was, but still 2-3 clunks. It still cranks for a second when heat soaked before it starts, and cracking the throttle open usually speeds up the starting process quite a bit
Could pull your spark plugs and peek at your pistons. Built up oil crud or carbon (from running too rich) will make hot spots that ignite your fuel and cause dieseling.
If you've done significant engine customizing (e.g. aluminum heads with special chambers, custom cam, etc) you may need or use a timing curve that you'd never think of on a factory motor so 36 max mechanical advance or 16 initial mechanical may not be too much. To be sure, I'm speaking with no vacuum here. If you're using full vacuum, 12 mechanical advance (with vacuum disconnected and plugged) is often enough.
Also, if you've customized your engine then it may like to idle at 850-900ish. Idling at 700 is more for factory builds with smallish cams.
I've got a new set of plugs I was gonna put in today actually, so as long as I can find a good flashlight I'll take a look in ther. Could running too rich at idle be a potential cause of this run on? I'm gonna hook up a vacuum gauge to it today so I can straiten the idle a/f ratio out.
unfortunately this timing stuff is pretty new to me, so how I go about modifying the timing curve is something that I need to do an it of research on to fully understand (unless it's simply referring to where your initial/full advance numbers are at, and not necessarily the line it follows going from A to B) I can tell you I'm running ported vacuum at the moment though, once I converted to a 5 speed it didn't like full vacuum at all.
The motor definitely sounds 100x better and healthier when it idles a little higher, I've got an rpm/dwell meter that'll be here tomorrow so I can be a little more precise with it
