Power to the fuel pump relay, no power to the pumps
My 90 F250 with 7.5l cranks but won't start. I replaced the coil, plugs, wires fuel filter, cap and rotor. After replacing the left side bank of plugs, the truck would crank but not run. I did some research and jumped the fuel pump port to ground on the EEC test plug and the truck still wouldn't run. I replaced the computer and still no love. I jumped the fuel pump port again and the truck fired up and ran 3 days, no problem. Then it died again and I'm back to the crank won't start condition. Here's the bad news.
Yellow wire to the fuel pump relay - 12v
Red with green stripe to fuel pump relay - 12v
Solid red to fuel pump relay - 12v
Black wire to fuel pump relay - 0v
Green with brown stripe to impact switch - 6.0 - 6.5v
Pink with black stripe at impact switch - 0v (tried with switch open and reset or closed)
Center wires coming into tank selector switch - 6 - 8v
Wires going out of TSS - 6 - 8v (works both ways)
I checked continuity at the fuel pump relay (new) check out good
I checked continuity at the impact switch, checked out good
I checked continuity at the TSS, checked out good in both positions.
I checked continuity of the wire from the fuel tank to the plug on the fender well, checked out good. Then the wire disappears into a giant loom, but I have continuity from the red/green strip wire and the solid red wire at the fuel pump relay to the red wire that goes all the way to the pump. Continuity but NO VOLTAGE. Can anyone help me determine what's going on with this mess?
Thanks.
Thanks.
Thanks.
Thanks.
Did you mean Tan with a light green stripe as opposed to Red with green stripe wire at the fuel pump relay?
Did you mean a Brown wire opposed to a black wire at the fuel pump relay?
It sounds like the Tan with a light green stripe is not being grounded by the PCM Computer.
Catchog
15
04-14-2016 03:44 PM
fishingape
02-11-2015 01:46 PM
fattmann
09-24-2007 11:44 PM
SteelySlayer
06-03-2006 01:59 PM
