2003 Ford Ranger extended cab rear door pannel removal? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-31-2003, 03:42 PM
chronos chronos is offline
chronos is starting off with a positive reputation.
I just purchased a 2003 for ranger extended cab fx4 and wanted to put nicer speakers in the rear doors but for the life of me canot get the rear door pannels off... how do they come off?
Old 08-31-2003, 03:51 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Hello chronos, welcome to Ford Truck Enthusisasts!
This thread might help....look for the link for removing rear door panels on a Ranger: Ranger Audio Tech Articles
Good luck! Let us know how it sounds when you are done.
Old 08-31-2003, 04:03 PM
thanks alot that site had exactly what i was looking for its nice to finaly find somewhere with instructions and pictures now no worrying about breaking the door thanks alot
Old 08-31-2003, 04:51 PM
Rockledge's Avatar
You're welcome.
Tempe, the guy who put thogether that Audio Tech Articles page, is a wiz at audio-related stuff and a very helpful member here at FTE!
Old 10-08-2003, 12:43 PM
Va914 Va914 is offline
Va914 is starting off with a positive reputation.
Any one have the new link to the tech article on Ranger Audio?
Old 10-08-2003, 01:42 PM
Rockledge's Avatar
95+ Ranger Front Door Panel Removal Tutorial
I've had some other people tell that they couldn't access Tempe's rear door removal tutorial at TRS ...so I converted the html page into a PDF file which should now be accessible:
95+ Ranger Rear Door Panel Removal Tutorial
Old 10-08-2003, 05:17 PM
WXboy's Avatar
WXboy WXboy is offline
WXboy is starting off with a positive reputation.
I took my door panels off last week to do the same. BE CAREFUL. I broke one clip on each side. One side actually broke the piece on the panel itself so it's toast. They are a nightmare to get off. Once off, you should remove all the clips still in the door, and reattach them to the panel. That will make the panel easier to pop back on. If I ever need to get to the speakers again, I'm thinking of cutting the panel around the speakers and making my own access hole there. It's ridiculous how Ford designed this thing on the 4-door models.
Old 10-08-2003, 07:39 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
WX, what did you break, the panel slides up it doesn't have the pins like the old ones did.
Old 10-09-2003, 12:30 PM
WXboy's Avatar
Mine had 12 clips. I call them "rivets". They are the push-in type and are a NIGHTMARE to get out. I ended up using pliers and a screwdriver after I noticed blood on my fingers. It's nuts.
Old 10-09-2003, 01:23 PM
Ken00's Avatar
Duh, I missed that you were doing the rear doors.
Old 10-09-2003, 09:13 PM
WXboy's Avatar
Oh, yeah. OK, I thought maybe the ones built at the other assembly plant were different or something. I was about to get jealous.
Old 01-18-2007, 08:15 PM
meyerje meyerje is offline
meyerje is starting off with a positive reputation.
First time to the forum, and everything here looks great I just bought a 99 Ranger XLT 4.0l V6, and I'd like to replace the front and rear factory speakers. The link for the front panel removal is great and a big help, however both the links for Tempe's rear door removal tutorial at TRS and the pdf that rockledge posted are bad. Can anyone repost the pdf or fill me in on how to do this?
Old 01-19-2007, 07:41 AM
ctboyle03's Avatar
ctboyle03 ctboyle03 is offline
ctboyle03 is starting off with a positive reputation.
The rear doors are insanely hard to remove. Not sure why its necessary to have those plastic rivet things every 6 inches... I guess if you have a panel tool it would make things a little easier. I think i just ended up pulling on the panel near where i could tell a clip was.
Old 01-19-2007, 08:08 AM
Rockledge's Avatar
Old 01-19-2007, 01:35 PM
That link works great, thanks!
swapping doors and other parts, please help.... Alan Kocinski 1997 - 2003 F150 0 07-03-2014 08:21 PM
Door pannel light lens postmortum 1987 - 1996 F150 & Larger F-Series Trucks 12 06-07-2014 12:47 PM
Rocker pannel rust repair? shore 1997 - 2003 F150 15 03-02-2014 11:07 PM
1951 Ford F-1 Door Lock Question burnettd01 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 10-01-2009 01:57 PM
how to remove 3rd row Speaker pitmanr2003 Expedition & Navigator 8 04-14-2009 02:31 PM
Tags
03, 2003, 98, back, cab, door, doors, electric, extended, ford, panel, ranger, rear, removal, remove, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
