Need help ID'ing part please!
I've been working on my 1985 E150, and I've come across a part that I can't identify. This is coming from a hose from off of the carb (return maybe?). Any help figuring out what it is would be greatly appreciated. Cotton
Last edited by CottonTexas; 03-29-2017 at 09:40 PM. Reason: Edited for (hopefully) easier reading
Standard CP402 Vapor Canister Purge Valve | eBay
Part number I found for 84/up E150 with 6 or 8 cylinder is E4AZ-9C915-A
I found this under CX-907
http://www.ebay.com/itm/Ford-Mercury...FVhdl7&vxp=mtr
photo is not showing up but what about this one?
New Ford Vapor Canister Purge Solenoid Assembly NOS
One of the first rules in posting questions is to tell us everything about the vehicle. You are a newbie so I'll overlook it this time. And, how it hooks up matters greatly on these trucks. But, here's what the setup looks like on a 460, with the part you are asking about apparently being 9B982:
Having said that, there aren't many different part numbers:
I appreciate your patience, but the pic was of a straight six, and I assumed everyone here would know it wasn't a 240.
If I assume you posted the right pic I might send you off buying the wrong part. You might have just posted it 'cause it showed the part you were talking about - as I did of the 460. PLEASE tell us everything about the vehicle that is pertinent. And the best way to do that is to put it in your sig since on multi-page threads I rarely take the time to scroll back up to the opening post and try to figure out what is going on.
Quick follow-up, I just ordered Ultra-Power PN: CP400 from R.A. Just wanted to let the good folks know that there are new pieces out there that carry a manufacturer's warranty - in case anyone's sketchy on NOS parts. Thanks again for all the helpful input. Cheers, Cotton
EDIT: Ultra-Power PN: CP400 is NOT the correct part. See post #19 for more info.
Part number I found for 84/up E150/350 with 6 or 8 cylinder is:
E4AZ-9C915-A I found this under (Motorcraft CX-907) / Obsolete
