Can anyone make sens of this early Bronco VIN?
Ron - You can use the 1980 part of the VIN decoder here: VIN Decoding - ???Gary's Garagemahal.
I get:
I get:
- U15: Bronco wagon
- G: Engine code, and "G" usually indicates a V8, but I don't know about an earlier Bronco
- L: Made in the Michigan plant
- 063005 is the "numerical sequence of assembly"
G = 302 2V
L = Michigan Truck Assembly Plant.
O63005 = 1977.
1977 Serial Number Range: O00,001-Z20.000. The letter O looks like 0 (zero) on the Warranty Plate, causing confusion, but one would assume a Bronco website would know this.
FoMoCo Passenger Car 11 digit VIN sequence is different than truck, Bronco & Econoline. Begins with a number that denotes the year.
Then there's a letter for the assembly plant, followed by two numbers that decode to the model and body style. 5th digit is the engine size, last 6 is the numerical sequence of assembly
Example: 5R08C123456: 5 = 1965; R = San Jose CA Assembly Plant; 08 = Mustang Convertible; C = 289 2V; 123456 = 1965 numerical sequence of assembly.
Beginning in 1981, all auto manufacturers vehicles sold in the US have a 17 digit VIN .. this was mandated by the US Gov't.
Prior to 1981: While FoMoCo vehicles had 11 digit VIN's, other auto makers VIN's could have 5 digits or 10 or who the hell knows how many digits, it was mass confusion.
btw: 1977 Bronco uses the same fuel filler door as 1977/79 F100/350 Stylesides, 1978/79 Bronco & 1974/79 Lincoln Continental Mark IV/V.
If the 1977 has an exposed fuel cap, the left quarter panel was replaced with a 1966/76 quarter panel.
