Now isn't this some real BS. I feel duped
They don't want you using adaptive cruise control with your trailer due to the possibility of unintended hard braking. I've had that happen to me twice in my wife's SRX. It's no big deal when your cruising along. With a trailer in tow it could be disastrous.
I would use the adaptive CC all the time, except when towing. I've never had an issue using standard cruise control when towing.
Where in NW Indiana are you? I'm in Munster.
I sincerely believe that Ford should clean that page up though. It is misleading.
Portage. I am one of those mill rats.
I worked at Inland Steel for a while. Started out on the hot metal benches, then was able to become an electrician while attending Purdue. We were hit with massive layoffs so I went to school full time. After graduation I came back to Inland in process automation. A couple years later they decided to save money and start outsourcing our jobs. That plan didn't work out so well for them. I kind of miss working at the mill.
I am an MTE (union speak for electrician) out @ Burns Harbor. Most of my work is process automaton. We have automated much of the production now.
The things we do out here are pretty impressive. We still need the same amount of operators to oversee the process. But the machines make it very repeatable. It is a fun job most of the time.
It is dangerous sometimes, and as an Union Electrician, it is a dead end job.
Knowing that the shop I work for is responsible for making the steel for all major automotive manufacturers (including Ford) it pretty neat too.
I enjoy going to work.....most days
First, let me say I was very pleased with the way my 2016 with a 2.7 tows. Other than the small tank gives it a short range while towing. Overall I was very impressed with towing when compared to a Super Duty.
I had an OEM trailer brake installed afterwards. Best to get it from and installed by a dealer, they must 'flash' (program) it to work with all the other trailer options available with the truck. That said, my 2016 manual states "Do not use the system when towing a trailer with aftermarked (sic) trailer brake controls. Aftermarket trailer brakes will not function properly when you switch the system on because the brakes are electronically controlled. Failing to do so may result in loss of vehicle control, which could result in serious injury. "
Surprisingly, you can certainly use a Ford controller with ACC.... I always thought they advised against using cruise with a trailer.
Trust me, you will love that truck!
So like a good owner, I have been reading the owner's manual in anticipation of taking delivery of my ordered truck........ forget about that for a sec.
For those that have ordered or shopped around, I am sure many have used the "Build & Price" pages on Ford.com. Many of the options offered have some sort of stock image, graphic or picture to help describe said option.
One such example is the picture shown for the adaptive cruise control. An $1,100 or so option.
I see that and think, wow, that would be a really nice option to have when taking family camping trips yanking the travel trailer down the road.
EXCEPT, the friggin owner's manual states that the trailer brake controller is not part of the adaptive cruise system. Moreover, any trailer equipped with trailer brakes should not be used with adaptive cruise control.
"Do not use adaptive cruise control
when towing a trailer that has trailer
brakes. The auto-brake component
of the adaptive cruise control system does
not operate the trailer brakes. Using
adaptive cruise control when towing a
trailer that has trailer brakes may result in
the loss of vehicle control, which could
result in serious injury."
So I just bought one of the more expensive options that will not work for the reason I intended.
I have half a mind to tell the dealer (even though it is not their fault) that I don't want it now.
That website is downright misleading. I have never seen a tandem axle fully enclosed vee nosed trailer not have trailer brakes. Hell, standard axles that size are almost always rated for at least 3500 lbs. So any trailer that would have two 3500lb axles would clearly be over the 3500 GVWR that pretty much every V5 range trailer manufacturer uses as a threshold for equipping a trailer with brakes.
Pretty much all states require trailer brakes for light duty vehicles towing trailers over 3500lbs.
Someone at Ford needs to correct this misleading information.
So I was watching some of the vids on the '18 MY. One of the people on there stated that the Adaptive CC can be used with the Integrated Trailer Brake Controller. He also stated that Ford had that feature for some time. Out of curiosity I checked Ford's owner's manual PDF and HTML pages today, sure enough, they have changed.
It looks like the IBC is designed to work with ACC.
The new quoted language.
"Do not use the system when towing a trailer with aftermarket trailer brake controls. Aftermarket trailer brakes will not function properly when you switch the system on because the brakes are electronically controlled. Failing to do so may result in loss of vehicle control, which could result in serious injury."
#28
#30
rangerbait
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
15
05-13-2015 09:49 AM
