Shocks, What Shocks? - Ford Truck Enthusiasts Forums
2017 Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 03-19-2017, 08:43 PM
natpark natpark is offline
natpark is starting off with a positive reputation.
So I have just over 6000 miles on my 2017 F250 diesel and I go under the truck today to do the first oil change and this what my Rancho shocks look like on both sides of the truck. Nice! Right. I will see what the dealer will do for me. I think I will need an upgrade. They look totally blown out with the boot cover melted from heat build up.
Old 03-19-2017, 09:04 PM
fordman19762003's Avatar
fordman19762003 fordman19762003 is offline
fordman19762003 has a very good reputation on FTE.fordman19762003 has a very good reputation on FTE.fordman19762003 has a very good reputation on FTE.
Wow, they must have gotten pretty hot to melt that plastic boot. I knew this was going to be a thread about the "Rancho" shocks before I even clicked on it since they have a very bad rep on here.
I would see if you could put on some real Rancho 9000s or another quality shock and pay the difference instead of putting the same thing back on.
Rancho needs to stop letting Ford use their name for these shocks because it's not doing Rancho any favors.
Old 03-19-2017, 09:15 PM
Boilermaker374 Boilermaker374 is offline
Boilermaker374 is starting off with a positive reputation.
Wow that's disturbing....... Gonna have to keep an eye on mine.
Is your vehicle stock??
Old 03-19-2017, 09:18 PM
DJ Cobb's Avatar
DJ Cobb DJ Cobb is offline
DJ Cobb is gaining momentum as a positive member of FTE.
I'm not sure any shocks would have survived the heat source that melted them.
Old 03-19-2017, 09:21 PM
wb6anp wb6anp is offline
wb6anp has a very good reputation on FTE.wb6anp has a very good reputation on FTE.wb6anp has a very good reputation on FTE.
I would like to know the heat source.
Old 03-19-2017, 09:26 PM
Quote:
There is nothing on the front end close enough to the shocks to heat them up that much.
My guess is the damage was caused by the combination of super hot fluid leaking out and the shock body getting hot from running dry. You can see how the hot fluid burned the paint off as it was running down the shock body. These things are cycling constantly and will heat up if there is not enough fluid to cool them.
Old 03-19-2017, 09:38 PM
I wish Rancho had the 9000's for the stack truck but doesn't appear they do yet
Old 03-19-2017, 09:48 PM
Kingofwylietx Kingofwylietx is offline
Kingofwylietx is starting off with a positive reputation.
Quote:
Originally Posted by fordman19762003 View Post
......I knew this was going to be a thread about the "Rancho" shocks before I even clicked on it since they have a very bad rep on here....
Me too! That was my first guess.
Old 03-19-2017, 10:07 PM
The truck is totally stock. No lift, stock tires, we did a far bit of gravel and wash board driving but at very moderate speeds in Death Valley. There is no heat source other than the shock getting hot and self destructing. I know these shocks are nothing to write home about but I would not have thought that driving 10 to 15 mph on gravel roads would have done this. Time for upgrade I guess.
Old 03-19-2017, 11:40 PM
347Flatty 347Flatty is offline
347Flatty is starting off with a positive reputation.
Quote:
Did you check out the rear shocks too?
Old 03-19-2017, 11:55 PM
TrikeDawg's Avatar
TrikeDawg TrikeDawg is offline
TrikeDawg is starting off with a positive reputation.
Rancho does have the 9000's available for the front F-350 but not for the rear.
Old 03-20-2017, 12:05 AM
ERock62's Avatar
ERock62 ERock62 is offline
ERock62 is starting off with a positive reputation.
Driving over washboards will not cause that. If the shocks get hot they will just start to fade.
Old 03-20-2017, 12:16 AM
f350ktm's Avatar
f350ktm f350ktm is offline
f350ktm is starting off with a positive reputation.
First time I have seen a shock look like it took that much heat. On the lower picture it looks like oil trace in the area. Possibly seal failures with loss of fluid or maybe lack of adequate fluid from manufacturing?
Maybe some improper components during assembly.
Almost looks like the one shock had a blow torch taken to it.
Old 03-20-2017, 01:06 AM
DingusKhan's Avatar
DingusKhan DingusKhan is offline
DingusKhan is starting off with a positive reputation.
Quote:
Obviously they can and did. The seals failed and the friction inside, without oil in there, caused enough heat to melt the covers and burn off the paint. The engine nor the brake calipers did that damage.
Old 03-20-2017, 06:30 AM
Karl4Cat's Avatar
Karl4Cat Karl4Cat is offline
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
Quote:
I agree. When mine blew out it was only the gas side (on 2 of 3 blown... one had both the gas and hydraulic seals blown) but these blew out the hydraulic seals too and the friction from running dry likely caused the heat. Yikes. In the FX4 thread there was a member calling Bilstein to see if they had a 4600 or 5100 available for the 17's yet. That's what I would suggest the OP of this thread do as well. If not, you could get them replaced at the dealer under warranty to buy some time until the aftermarket catches up on the 2017's.
On a positive note, the 2017's ride so nicely that you didn't notice that both your front shocks were now paper weights!
Need parts identification help texbigred1 1999 - 2003 7.3L Power Stroke Diesel 4 03-20-2017 06:48 PM
First DEF fill up Robeleo 2017 Super Duty 16 03-20-2017 01:48 PM
How does it work? Chuey 2017 Super Duty 17 03-20-2017 12:03 PM
New F350 and the first mod! noimports 2017 Super Duty 9 03-20-2017 03:03 AM
1999 f 350 major issue Archerydeer 1999 to 2016 Super Duty 1 03-19-2017 05:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
