Getting Ready to do a Clean Wiring Install
Getting ready to install a new harness on my frame off rebuild for a 1962 Flareside. Just about ready to put the cab back on and will start the rewire. I'm asking for any tips or tricks you might have when rewiring one of these. Any help is appreciated.
Engine installed after fabbing engine mounts for frame.
Dennis, right?
For authentic style reproduction harnesses many people are going with this company. They apparently do a fairly exacting version with correct connectors. I can not say myself as I have not used them yet, but they have a good reputation.
Wiring Harnesses - Narragansett Reproductions - Wiring Harnesses and car restoration supplies
EDIT: Their Ford catalog is here. Scroll down to Commercial section for trucks, past all of the cars. About page 22....
http://www.narragansettreproductions...parts-ford.pdf
Chad
Chad
I like Bill's saying. "You thought you bought a truck, but you really bought a hobby, and hobbies tend to be expensive."
I always nod when I hear that one.
It depends on what you want to do. These high-end reproduction harnesses might be better for a high-end restoration.
Many of the kits are at least somewhat universal and/or let you add extra circuits for electric seat warmers, backup cameras, etc. etc.. The idea is to remove all of the existing wiring, then use the connectors that come with the universal kit. Some of the fit and finish is left up to the installer in those cases.
One I have had experience with is M+H Fabricators. I and many others have used them for GM harnesses. They do nice work with original wire colors and connectors. But, they don't do Ford products.
Reproduction Wiring Harnesses for America's Muscle Cars
Here is what I am using. Keep in mind I am not restoring the truck but making a more modern one in the areas of power and safety.
You are here: Shop Home >> Categories >> EZ Wiring Kits & Switches >> EZ Wiring Harness Kits
EZ Wiring 21 Standard Color Wiring Harness Kit
All EZ wiring kits use GXL 125 high temp cross linked polyethylene jacketed wire that is grease, oil, gas, and acid resistant. Each wire is labeled every 5” Its entire length so checking a circuit is EZ ! COLOR coded wire! EZ wiring is the EZ way ! Each circuit wire is labeled so you know exactly where it goes -- EZier to wire --
EZier to trouble shoot ! Our best kit -- the EZ-21 - contains 18 fuses and 21 circuits.
http://www.ezwiring.com/store/ccdata...geMain_0_4.jpg
+ EZ 21
+ 18 FUSES 21 CIRCUIT
+ Radio, Coil, Dome Light, Backup/Cruise, Horn, Cigarette Lighter, Fuel Pump, AC/Heat, Radio, Turn Signal, Horn, ACC, Wiper, Gauges, Hazard, Fan, Power Window, Power Door Locks, Brake, Headlights (Color & Black have same)
Your Price:
$185.00
+ EZ 21
Your Price:
$185.00
hope this doesn't get me in trouble with the FTE powers that be. i'm NOT actively selling this tool, but it's just sitting in my toolbox and i'll never be used again, most likely.
anthony f47
10-04-2016 05:04 PM
Tilleyman
25
01-18-2014 08:40 AM
Poison Oil Racing
16
05-29-2013 03:14 AM
showtime946
01-19-2004 11:18 AM
