First time in 4x4 in my new to me truck. Driveline noise
I bought my 2012 F250 CC SB 6.2 back in December and really haven't had the truck in 4x4. Today we got a bit of snow. The roads were slippery so I engaged the 4x4 ESOF while at a stop sign (I know, didn't have to be stopped but I was so I put it in 4x4) The driveline was noticeably louder. I had a relatively constant hum that almost reminded me of a wheel bearing going bad. If you've ever experienced a wheel bearing going bad the sound gets louder as you go faster. I'm sure it's not a wheel bearing since it only makes the sound in 4x4. It's a fairly annoying sound and is louder than my old 99 F350. Anyone else notice the driveline being significantly louder in 4x4? There are no driving issues just a louder sound than what I was used to. I have the full Ford Certified warranty and can bring it in but I thought I'd run it by the brain trust here to get thoughts before going to the dealer.
My first thought would be to check the u-joints on both the front driveshaft and the front axle since they will all spin in 4x4, but not in 2wd. A u-joint with failing needle bearings will often make a whine for a little while before it completely locks up. It would also have the speed sensitive noise that you are describing.
Thanks for the reply!
Also check the front diff fluid level. My mothers 2005 GMC 2500HD had a similar in 2008. You have to run 4x4 at least 10 miles once a year (according to GM) in order to keep the fluid and u-joints greased/lubed and in working order. Her truck she bought new and only has 41,000 miles on it. Your trucks previous owner probably haven't ran it that much in 4x4.
Originally Posted by RainDesert
My brand new truck hums in 4x4. I have posted this topic in the 2017 section. I got a few responses that there previous gen SD's hummed also. Thing is, I've had about a dozen SD's in my life, and not one ever hummed like my new one. I can get it to go away when I'm coasting or left of the gas, but under any pedal pressure, it hums. It doesn't seem right to me.
My brand new truck hums in 4x4. I have posted this topic in the 2017 section. I got a few responses that there previous gen SD's hummed also. Thing is, I've had about a dozen SD's in my life, and not one ever hummed like my new one. I can get it to go away when I'm coasting or let of the gas, but under any pedal pressure, it hums. It doesn't seem right to me.
Ron, It reminds me a lot of the sound of a wheel bearing going bad. I have a lot of experience with that problem from owning an Explorer.
