2001 f350 diesel intermintent engine dying
My 2001 F350 7.3 dually diesel Automatic has been a pretty good truck but recently it has been dying. Engine just randomly shuts off without warning while Driving. Check engine light comes on sometimes. Some of the time it will restart if I cycle the key. Once its running again I can rev the engine up without a sputter but after a few hundred yards down the road it will die again. I noticed driving on the highway when it does it my truck will buck first, then...
If I leave it in drive with the key in the run position when it dies and I'm coasting down the highway the Tach starts jumping around like its trying to restart itself, all on its own.
I don't have a scanner
Any ideas or need any other info?
Appreciate the help!
Mike
Mike
Change out your CPS and see if that helps it's an easy fix. Replace it with the one you get at the Ford dealer, aftermarket Crank Position Sensors have been known to be flakey and inconsistent. One way you can tell if the CPS is bad is when it fails and cranks without starting look at your tach. If it doesn't read the rpms the CPS is bad.
Ok guys
Just put new ford "grey" cps on. It had a "black" cps on it
Will take a drive shortly and report back.
I'll try unplugging the ICP just to try that also
I've also ordered the IPR sensor also, should be hear tomorrow
Haven't been too pressed to get running as I have another vehicle/jeep and was waiting for a little warmer weather
Will report back soon
Appreciate all the help guys
Mike
Mike
dlbrooks2658
15
12-01-2007 11:24 AM
