Need help selecting the right stall
I have selected a cam and here are the specs :
Basic Operating RPM Range: 2,200-5,900
Intake Duration at 050 inch Lift: 235
Exhaust Duration at 050 inch Lift: 249
Valve Lift with Factory Rocker Arm Ratio: 0.541 int./0.526 exh
Now I would like to know if this Stall converter would be a good fit for this cam,
Stall converter : https://www.summitracing.com/parts/ape-24402/overview/ (Stall range is 2,200rpm)
Other factors that come in to play :
Tire size : 31 x 10.5
gears : 3.55 gear ratio
Trans : E40D stock
Heads : 165cc afr heads
Intake : 3881 edelbrock(idle - 5,500 rpm range)
Rocker arms : 1.6r roller rockers
Now once again all I want to know is if this stall converter would be a good fit with this cam / and the selected components.
I look forward to hearing your advice
Trans : E40D stock
a63unibody
10-30-2010 02:56 PM
Kirbys73F100
07-16-2010 09:25 AM
olered53
12-28-2005 05:36 AM
water 5
08-08-2005 04:36 PM
