Steering parts blues....
Old 03-14-2017, 10:03 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
Hey guys, I only have one more part to buy for my axle swap and it can get underway.
I am having trouble finding the steering component that goes between the two knuckles. The longest piece with a hole in it for the drag link, 52" (or so) long. It came off of a 1992 F350 (Ball joint Dana 60)
Here's a picture.
Anyone have a part number or source for a new component? I can't find it ANYWHERE
Old 03-14-2017, 10:49 AM
knottyrope's Avatar
knottyrope
knottyrope is offline
AutoZone Duralast Tie Rod long
Part Number: DS1071
Alternate Part Number: EGDS1071
Duralast Center Link DS1071 - Read Reviews on Duralast #DS1071
Its what I put on mine last summer
Old 03-14-2017, 11:40 AM
dclack's Avatar
dclack
dclack is offline
I'd get Moog only. Rockauto has them:
DS1071
DS1068
ES3009R
Or for a little more, buy this kit: "Y" Link Steering using GM 1 Ton TRE - RuffStuff Specialties
The nice thing about that is all you will ever have to replace is just the TREs ($129) and not the whole tube.
Old 03-14-2017, 12:02 PM
97-psd's Avatar
97-psd
97-psd is offline
Those ruff stuff kits are sweet. I just put one of the autozone links last year. No complaints so far.
Old 03-14-2017, 02:43 PM
Jarrett Campbell
Thanks guys! So would I need to get the under the knuckle or could I drill the knuckle out and use the inserts for over knuckle steering
Old 03-14-2017, 02:56 PM
dclack's Avatar
dclack
dclack is offline
The Ford taper is different than the GM, so you would need to either ream the knuckle for under or drill out and use the inserts for either over or under.
Old 03-14-2017, 06:22 PM
Jarrett Campbell
That's good to know... What is better I guess would be the next question.
Old 03-14-2017, 08:05 PM
Kingkong0192's Avatar
Kingkong0192
Kingkong0192 is offline
Are you asking between over the knuckle and under the knuckle or reaming the knuckle versus inserts?
Over the knuckle is good if you do a lot of off-roading. It keeps the steering higher up and less likely to get hit.
If you're just daily driving the thing there's nothing wrong with under the knuckle.
I think the reamer is around $110. The inserts are $15. The inserts work more than fine. I have them on my truck with no issues.
Old 03-14-2017, 08:48 PM
Jarrett Campbell
Gotcha. as cool as that setup is, I think I will be going with the stock stuff for now. As soon as these parts wear out, I will do it, I just need a quick simple fix right now. With the axle swap, I need as few variables as possible.
rbond
28
01-23-2021 07:45 PM
Kenerly
1999 to 2016 Super Duty
12-14-2017 09:05 PM
Notmeofficer
Large Truck
08-30-2017 06:30 PM
crtjpn2003
07-29-2014 06:54 PM
den222
12-21-2009 02:35 PM
Quick Reply: Steering parts blues....
