Best plugs for 98 F150 4.6L? - Ford Truck Enthusiasts Forums
Old 08-30-2003, 11:10 PM
Fordman65's Avatar
Fordman65 Fordman65 is offline
Fordman65 is starting off with a positive reputation.
Fist of all, THANKS RACERGUY for the pointers on changing the spark plugs!! I'm not sure I would have been as motivated to change them without the guidance. Anyhow - my question is, what are the best plugs for performance, milage etc? Any suggestions? Thanks for the input!
-Aaron
Old 08-31-2003, 12:02 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Motorcraft is the way to go. They last along time and are priced right. Performance is good too.
Jimmy
Old 08-31-2003, 10:33 AM
CM113's Avatar
CM113 CM113 is offline
CM113 is starting off with a positive reputation.
i asked the same question and they are saying that motorcraft are the way to go,thats what i will be useing
Old 08-31-2003, 11:18 AM
AegisSailor's Avatar
AegisSailor AegisSailor is offline
AegisSailor is starting off with a positive reputation.
Maybe Racerguy should add this question to the FAQ. It sure is comming up alot lately.
Old 08-31-2003, 02:27 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Good idea AegisSailor
I added it to the FAQ's and also to the "how to" thread.
Take a look and see if there sohuld be any changes when you get a chance.
Old 08-31-2003, 02:34 PM
Bob Ayers Bob Ayers is offline
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
Dave,
Autolite & Motorcraft spark plugs are both made by Honeywell,
a division of Allied Signal. Fram is also a division of Allied Signal,
and you are correct about not using anything with a Fram name
on it....
Old 08-31-2003, 02:59 PM
Looks good buddy. The FAQ is really comming along Haven't seen that door ajar question in a while!
Old 08-31-2003, 03:00 PM
Racerguy's Avatar
I was told that Motorcraft plugs werent made by Honeywell anymore but that could be wrong
I've seen a lot of problems with Autolite plugs and have heard of other people with problems with them too.
Old 09-01-2003, 10:26 PM
bosshoss bosshoss is offline
bosshoss is starting off with a positive reputation.
My vote is for Motorcraft from ford, i request them every time.
Old 09-02-2003, 06:55 AM
BlueOvalFitter's Avatar
BlueOvalFitter BlueOvalFitter is offline
BlueOvalFitter is gaining momentum as a positive member of FTE.
Yes,it is true Autolite and Motorcraft are both made by Allied-Signal,who is owned by Honeywell.But,Motorcraft are made to a different specification then Autolite.Ford has them made to there specifications.How do I know this?I was curious about it,so I emailed www.autolite.com and they themselves sent me an email stating all the above information.
So,if I were to use a plug in my Ford,it would be a Motorcraft.
Old 09-02-2003, 09:58 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
I would shy away from the NGK Iridium. As soon as I installed them the truck was harder to start. I would guess that the gap is excessive but the instructions said not to adjust the gap because the tip is so small.
They are also very expensive.
I am tempted to find a set of Motorcraft and install them. I find more and more reasons to stay with stock components.
Old 09-03-2003, 06:31 AM
Since only the center electrode is iridium, half of your plugs will
wear out prematurely, due to the opposite spark polarities with
the EDIS ignition system...Stay with Motorcraft double platinums!!
Old 09-04-2003, 01:14 AM
CPerry's Avatar
CPerry CPerry is offline
CPerry is starting off with a positive reputation.
Bob, just curious. Why not use Fram products? Are they junk?
Old 09-04-2003, 06:22 AM
Quote:
The oil filters are.....there has been a lot of posts on the problems
with Fram oil filters......Personally, I'm a believer in using the
manufacturer's OEM oil filter, so I use Motorcraft on my Fords,
and Mann (German filter mfg.) filters on my Mercedes'
Best plugs for 5.4L docweld 2004 - 2008 F150 22 02-10-2013 03:41 PM
Best spark plugs for my '96 5 liter hank1996 1987 - 1996 F150 & Larger F-Series Trucks 6 07-19-2010 05:39 PM
The best spark plug? dsljay Explorer, Sport Trac, Mountaineer & Aviator 3 11-05-2008 11:21 PM
Best Spark Plug Wires And Plugs ? longbowhunter 1987 - 1996 F150 & Larger F-Series Trucks 7 03-29-2008 01:44 PM
spark plug question 360 cu '74 ford BrettCox FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 0 09-14-2004 07:09 PM
Tags
150, 46, 98, f150, plugs, recommended, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
