2001 F150 4x4 - vacuum reservoir location
Old 03-13-2017, 02:12 PM
66with352's Avatar
66with352
66with352 is offline
Can anyone tell me where the vacuum reservoir is located on a 01 F150 4x4? I'm troubleshooting the 4wd not engaging want to check the reservoir. Any help would be appreciated
Old 03-13-2017, 03:12 PM
pdqford's Avatar
pdqford
pdqford is offline
Between the battery and the inner fender.
Old 03-13-2017, 04:39 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
....or INSIDE the fender.
Follow the hose....
Old 03-14-2017, 08:58 AM
alloro's Avatar
alloro
alloro is offline
Received 4,196 Likes on 2,432 Posts
Behind the battery.
File Type: pdf
Old 03-14-2017, 04:06 PM
66with352's Avatar
66with352
Thanks everyone - I saw the line tucked behind the battery tray but couldn't see a reservoir. I''ll check again when it stops snowing !
Old 03-14-2017, 04:52 PM
pdqford's Avatar
pdqford
pdqford is offline
IIRC, the reservoir is only about an inch thick,
and clips to the back side of the battery box.
Old 04-03-2017, 12:53 PM
66with352's Avatar
66with352
So I finally had an opportunity to get into the 4wd issue of not engaging again. I found the vacuum linkage (shaft with notch that moves the differential fork) and the differential fork separated. I pulled the vacuum arm out and reconnected them. The arm that engages the differential is a little sloppy and can move front to back causing the linkage to separate. I see a pin sticking out of both ends where the differential fork is mounted. Is there a way to tighten that arm? That pin is hollow. I thought it was an allen but it doesn't seem to be. Any suggestions??
Edit - Adding picture
DENNY1968
1997 - 2003 F150
09-19-2010 08:34 AM
DBKER31
1997 - 2003 F150
16
07-14-2009 11:20 PM
gcbyrum
04-29-2008 07:24 AM
jarnold
1997 - 2003 F150
03-15-2006 06:23 PM
Quick Reply: 2001 F150 4x4 - vacuum reservoir location
