They'll likely be the very same, or at least similar, wheels. Bolt pattern will all be 5 x 8". Both 20" and 18" were fitted during that whole era. You may have varying rim widths., and varying center disc offset positioning. The narrowest width being 3.75", more common being 4.33", and others wider for special applications. Single rear wheel styles also were used back then. If any that you get are 18"s I want to know about them. Also I can help you identify what you have based on Budd numbers. Stu
We put the wheels from my 1940 1-1/2 ton panel fire engine on a 1935 fire engine while the wheels from the 1935 were being painted and getting new tires. Worked fine.
