Need help identifying connecting rods
I just bought a 72 351c block and it came with crank, cam, rods and pistons, the rods have a casting number C8OE-A AQ51 and the pistons have a 351c cast in them, everything I researched says those are 302 rods and I don't know why 302 rods would be attached to a 351c piston. I'm having no luck researching so if anybody knows what I have that would be appreciated thanks!
302 rods at 5.090 are a little shorter than 351C rods so maybe this was the beginning of someone's stroker project. (old school, budget stroker?)
What does the crank look like?
Some dimensions and other info here:
http://raceabilene.com/kelly/hotrod/engine.html
no need to take it to the machine shop. Save your money and just attach One piston and rod on the crank and put it in the block. It either fits or it doesn't. if you cant do that you shouldn't even attempt a rebuild, and just farm the whole thing out to the machine shop. I guesse it all falls down to your ability to do the required work. If you have never done it, it sounds donting, but it really isn't.
77custom408
03-12-2017 05:20 PM
Bucsfan552
08-17-2009 11:25 AM
Rat wagon
15
02-21-2003 01:09 PM
TMI
11-25-2002 02:19 PM
