Manual transmission issue 94 f250
1st and 3rd gear puts my shifter in the dash. First off I had Lost shifter bushings, so it had some play.NOTE before loosing bushings, shifter was perfect working order. I finally found bushings through a private seller, After almost two years. I install new bushings and install my shifter but now my shift pattern seems out of place and 1st and 3rd will give you some nice bruises against the dash. No longer any play but, just not where shifter should be. Any help would be greatly appreciated.
Everything seems to be proper, I really don't know how to explain it lol. Especially since it's been parked since the shifter broke bc I couldn't find the square bushings."3 years". The posistion of shifter was fine at that point. Now The shift pattern is nice and solid minus the fact my odds are in the dash. No wiggle or play. No added length from weld either. No angle change as well. Only thing I know to do at his point is to make myself A nice custom bent chrome shifter. Or a short throw shift setup. Not really a fan though.
Received 3,102 Likes
on
nicksorenson
22
07-09-2017 07:03 AM
