Gas pedal recomendation
I have the Lokar Standard Billet Aluminum throttle pedal however when mounting it to the firewall with the 2 little screws it was filmsey and not really a solid mount, so if you look at the picture I made a billet aluminum pad with a recess in the center for the pedal to slide into and mounted it that way..works good, if you blow up the pic you'll see the piece I'm talking about that I had to make.
and is securely mounted to the floor, uses all Lokar throttle cables and hardware,.
I have the same one as DonVito and had the same issue. I used longer screws and move the pedal location a bit to get a better mounting surface. This helped sturdy it up. I'm sure DV's solution would be even better!
I do have a standard stamped steel firewall mounted pedal that came with the truck. It's in good condition and free to the original poster if that's what your looking for. OR anyone else that is need of it. Don't want to give it to someone that does have an exact need for it.
DGMFORD
09-20-2012 05:13 PM
superman64011
16
03-09-2005 08:07 AM
