Rear ABS light 1992 F-250
My '92's Rear ABS light comes on most of the time when I hit 40 mph. I had installed new taillight bulbs and they also seemed to knock out my cruise control. I have tried replacing the stoplight switch and now the ABS light doesn't come on every time. I really don't want to change out the bulbs (they're LED). Anybody else have this problem?
The 1994 F-series truck was the first one to have the stop light cargo light combination.
Note the RABS codes are read from the flashing yellow ABS lamp and not the MIL (CEL).
The possible flashout codes are listed and explained in the «Flash Codes Chart». Note that Codes 1 and 16 are not used.
When a code has been obtained, go to the Test indicated by the number of flashes. For example, if the flashout code is nine, go to Flashout Code 9 for the next step in diagnosing the problem.
jethrodean
08-21-2020 01:08 PM
