1952 F1 1/2 Ton speedo gear
Old 03-09-2017, 06:15 PM
rnelson664's Avatar
rnelson664
rnelson664 is offline
Looking for a speedometer gear for my 1952 3 speed. Can find 1953 and up but not the '52. Any idea who has them and does anyone have a picture of one so I know what to look for?
Thanks?
Ray
Old 03-09-2017, 06:55 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
DRIVE gear (on the output shaft) or DRIVEN gear (at the end of the cable)?
Rear axle ratio must also be known.
Old 03-09-2017, 08:20 PM
rnelson664's Avatar
rnelson664
Sorry about that. Driven gear at the end of the cable.
Thanks
Old 03-09-2017, 08:24 PM
rnelson664's Avatar
rnelson664
3.92 gears in the rear.
Old 03-09-2017, 08:31 PM
mOROTBREATH's Avatar
mOROTBREATH
mOROTBREATH is offline
What is your rear axle ratio? I seem to remember Bill also needs to know your tire size using the notation of vintage sizes. For example, a modern tire size of 195/70R14 is equivalent to a vintage tire size of 6.50-14.
I guess Bills chart works only in vintage sizes. So you'll need to figure out your current tire size, then find a conversion chart to see what vintage size your modern tire corresponds to.
Old 03-09-2017, 08:46 PM
rnelson664's Avatar
rnelson664
Need end of speedo cable gear, 3.92 gears, 600x16 tires.
Thanks
Old 03-09-2017, 08:53 PM
NumberDummy
O1Y-17271-F .. 23T Speedometer DRIVEN Gear / Obsolete
1950/52 F1 with 3 M/T, 3.92-1 and 6.00 x 16 tires.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
COLLECTORS AUTO SUPPLY in Blaine WA shows 1 = 800-414-4462.
When you call this place, they usually say they have to 'check the warehouse,' but their warehouse is usually a Ford dealer on a site that the general public cannot access.
No Ford dealer has any, so Collectors may have it, may not.
Old 03-10-2017, 10:39 AM
rnelson664's Avatar
rnelson664
Here is what I took out of the tranny. No speedo gear was attached. Does this look correct for a 1952 F1 3 speed? Is this the end of a speedo cable? I'm pretty sure it's an 3 speed overdrive tranny. So, would part # O1Y-17271-F work with this?
Thanks
Old 03-10-2017, 11:22 AM
NumberDummy
If it has Overdrive, O1Y-17271-F is the WRONG speedo DRIVEN gear.
But Overdrive was not available until 1953 (F100).
Overdrive engaged via a cable located to the left of the steering column under the dash, mounted to a bracket.
Pic: Borg-Warner 3 M/T with Overdrive: 1953/56 F100
Old 03-10-2017, 11:55 AM
rnelson664's Avatar
rnelson664
Yup, that's it! I can't thank you enough for the help. The speedo driven gear is abundant for this year tranny.
Old 03-10-2017, 12:35 PM
NumberDummy
Yup, that's it! I can't thank you enough for the help. The speedo driven gear is abundant (!) for this year tranny.
If your 1952 F1 has a swapped in Overdrive, the 3.92-1 speedo DRIVEN gear is B5A-17322-A 20T
NOS PARTS LTD in Waxahachie TX has 5 = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has 8 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 905 = 800-476-9653.
I'm pretty sure I've seen this gear listed in Carpenter's 1948/56 truck repro parts catalog.
Old 03-16-2017, 03:53 PM
rnelson664's Avatar
rnelson664
Speedo gear inside tranny
OK, thank you to everyone for your help. I got the correct cable and gear. I have another question. When I put my finger into the tranny where the gear and cable go I feel a gear. It must be the gear that turns the speedo driven gear. I can spin it freely even when the tranny is in gear. Of course it's not running when I'm spinning it. Is this normal? Seems like when the tranny is in gear it shouldn't spin until it's moving forward. Hope this makes sense.
Thanks,
Ray
Old 03-16-2017, 04:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
The speedo drive gear is keyed to the mainshaft, see below. It should not spin.
I'd be interested to see the installation of the OD trans in a '52; many have tried and failed. Do you have the brake MC in the stock location?
Old 03-16-2017, 05:32 PM
rnelson664's Avatar
rnelson664
Actually, turns out to be out of a 1956, not a 1952.
wavetrain75
12-03-2012 07:09 PM
harleymsn
11-22-2011 07:19 PM
BiltFordTuff
07-23-2011 04:53 AM
DutchmanAZ
06-09-2010 02:10 PM
TXDod65
04-19-2006 11:26 AM
Quick Reply: 1952 F1 1/2 Ton speedo gear
