Leaking rear differential
Old 03-09-2017, 05:12 PM
Fordtrucer's Avatar
Fordtrucer
Fordtrucer is offline
Hey guys I'm trying to figure out what axle I have on a 2002 f350 single wheel 4x4 so I can order a replacement seal. So this morning I got to work and noticed that am oily guild was dripping from the front of my rear differential where the drive shaft hooks into it. I figure it the seal, so when I went to look up the repair kit they list several different axel options because of gearing I have no idea what axle I have as there wasn't a ln owners manual with the truck. Who can I find out what axle I have so I can buy the repair kit for it thanks. Guys.
Old 03-09-2017, 06:05 PM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
Scroll down about 3/4 of the way down this page to find axle information for what it was manufactured with.
Super Duty Identification Codes
Old 03-09-2017, 06:25 PM
Whitey Ford's Avatar
Whitey Ford
Whitey Ford is offline
FTE-Spread The Knowledge
Check the air line that is on top of the differential to make sure it is not clogged. It prevents the differential from breathing and the pressure blows out the pinion and wheel seals.
Good luck.
Old 03-11-2017, 07:23 PM
retiredsparky's Avatar
retiredsparky
retiredsparky is offline
Good reminder about that vent tube. The little bit of oil that accumulates will cause dirt stick to stick in the end of the tube.
Old 03-12-2017, 02:30 PM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
Won't the stcker on the door jamb indicate which rear end it left the factory with?
Old 03-12-2017, 03:06 PM
Rikster-7700's Avatar
Rikster-7700
Rikster-7700 is offline
Have you looked for the tags in the differential itself? They will let you know the gearing and such you have going on....
oklarado
2017+ Super Duty
07-17-2017 01:08 PM
ExPACamper
32
07-07-2017 04:59 PM
XTfx4
06-11-2013 03:42 PM
joonya
2004 - 2008 F150
04-02-2012 10:15 PM
rgconway
07-11-2008 08:42 AM
Quick Reply: Leaking rear differential
