Boat Trailer Brakes
Boat Trailer Brakes
Well I am going to be rebuilding the brake system on my boat trailer this spring and hoping to get some input from some of you guys who have done brakes on boat trailers. Mind you for you guys that don't have a boat trailer that boat trailers have surge brakes or electric over hydraulic.
I'm thinking replace the master cylinder, all brake lines, new loaded backing plates and have the drums cut or replaced also.
My trailer is a 1982 EZ Loader with 6 lug with bolts not studs 16.5 wheels with surge brakes on both axles. I have no rating sticker on the trailer so I have no idea what axles are under it. The boat & trailer weight 8k to 8500lbs and the trailer was set up for this boat when it was new. Mind you I have had this boat & trailer for over 20 yrs. and all I have ever done is repack bearings and had to deal with the surge part sticking to the point I would have to give it a good hard pull to unlock brakes. That is why I am going to just rebuild the system or upgrade it all together. I looked into the electric over hydraulic for 2 axles and it was over $1000 which is too costly for me. So if anyone has found any discount boat trailer parts or have any suggestions please let me know. Thanks
Oh yea the 16.5 tires are also 20 yrs old and I haven't been able to find any 16.5's that I would put on my trailer. So I am going to buy 16" rims for it.
Any ideas there?? So far I have used Etrailer for other trailer parts but I am always looking for better deals.
Boat trailer fun. Ugh!!!
I am in the process of rebuilding my 10 year old Karavan Trailer as we speak, should finish it up this weekend. I have been using Pacific Trailers located in Chino California for my parts. Very fast shipping and good customer service if you have any questions. They seem to be a few dollars cheaper than Etrailer on most items that I needed. I am replacing everything but the axles and springs, all braking components are new. I converted a previous boat trailer I owned to Disc brakes due to the sticking issues of the brake drums. I found Disc brakes to be less problematic. I launch exclusively in salt water and the salt just destroys brakes no matter how **** you are about up keep. The new trailer is getting Disc brakes. You do need to make sure that you have an actuator that is made for disc brakes. In the salt water environment, Disc brakes just last longer, and when you need to repack bearings the calipers come off easier than drums.
PS - All hydraulic.
PS - All hydraulic.
My small single axle boat trailer has disc brakes and my large tandem axle boat trailer has drum brakes. Both are surge systems. I am going to have to rebuild/update my large trailer this year, too. I have been thinking about going to disc brakes and staying surge, but haven't locked into anything yet. I'll be watching to see what you do and how that works for you.
This is the kit that I am going to switch to, has everything needed.
HydraStar Marine Electric Over Hydraulic Actuator w/ Breakaway and 7-Way RV Harness - 1,600 psi Hydrastar Trailer Brakes HS381-9067
They also have a fixed coupler to replace the sliding one.
Titan Zinc-Plated Straight-Tongue Coupler - 21,000 lbs Titan Straight Tongue Trailer Coupler T4853100
From my friends that have done the swap to electric over hydraulic they love it, the brakes now work when backing down the ramp.
PS - All hydraulic.
PS - All hydraulic.
What brand did you use? Did you go with a manual reverse lock out or electric? Now from what you have said and from I have read on the interweb disc brakes are the way to go. And as I start researching parts & kits I ran into salt testing results which explains cost differences.
http://www.kodiaktrailerbrakes.com/a.../corrosion.pdf
Now I boat in fresh water on Lake Michigan but I do have plans to take it to salt water once I get this trailer dailed in. But I am going to have to weigh the cost verse budget concerns????
So as far as brand wise in brake kits I am seeing Titan and Kodiak is there any other quality brands you guys know of??
Thanks for all the input !!
I have two 3500 lb axles on my boat trailer, its only a 21 Cuddy Cabin. I went with Kodiak because they got the best reviews on all of the boating websites I frequent. I went with an electric lockout, manuals are a pain in the behind, because I never seemed to parked quite right to get the pin in the hitch. As far as brands another one is UFP made by Dexter. Good luck with the project, I don't think I have ever spoken so many cuss words before.
Brake parts around $900 not including bolts, fuild and brake lines... all for a STUPID trailer!!!
And I haven't even started to fight with 35 yr old rusted parts YET?!?!
The things we do to get our boats to the water. But better that then being broke down on the side of the highway. Or at least that is what I keep telling myself.
My wife would rather spend that money on a boat slip for the season. But I am trying to explain that with a good trailer we can go to many different places.
I'm fortunate in that the boat ramp is only a couple blocks from my house, so I don't have far to go to get launched. However, my 1996 trailer is showing it's age in many ways, so I'm eventually going to have to do the same stuff. This trailer isn't original to the boat, so I may end up changing the axles while I'm at it.
I have a very steep driveway, so in order to increase clearance for the outdrive when I turn into the driveway, I am considering changing from the 15 inch wheels to 16 inch wheels. The downside is having to get deeper on the ramp for launch/recovery.
15 inch wheels with EZ lube hubs
The coupler is more of the same - it really needs to be replaced with something sexier.
Granny panties style coupler
I think that I'll eventually go the disc brake route too, so hope you keep this thread updated with what you choose, how easy it is to install, and how well it works.
Good luck!
Good luck!
lostmybeer
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-14-2007 11:33 AM
ws595
11-18-2005 09:52 AM
SLAB
22
05-21-2005 02:28 PM
ChrisY
01-25-2005 08:29 PM
victorcharlie
09-19-2004 03:05 AM
