Limited slip, traction lok, etc..
I had some questions during my search for a truck.
How much strain(if any)does this put on a rear end compared to a standard open differential(assuming the previous owner was taking care of his truck)
In other words, all things being equal, would you want limited slip/position-traction or is this pretty much not a dig deal?
I'm in Texas and driving on ice covered roads is very rare though deadly because we don't use road salt. I stay home unless it's an emergency to drive.
I've looked over some previous threads and didn't find a specific answer,
Thanks for your responses.
Factory limited slips aren't "tight" enough to worry about any damage they might have done to anything. I certainly wouldn't worry about a truck because it has one. In an older truck they are generally worn out (my truck with ~190K miles on a factory limited slip will easily light up one tire). So if you think you would prefer an open diff I don't think you'll notice any difference, at least in any bad way, with a limited slip.
edit: I will add that although limited slip can help you get started better on ice it can also make it easier to spin out. So still be very careful driving on ice.
This should should keep you busy for awhile. I hope you like to read
The latest debate: always-stuck-only-1-tire-spins
And a good guide with just about everything you need to know about differentials: nothing-special-s-guide-to-differentials
Enjoy
Enjoy
Buck Dharma Fan
35
02-10-2011 07:56 PM
eco
03-26-2007 02:39 PM
