So I didn't give the clutch enough gas at a stoplight and the truck died. Went to restart it and it only turns over and cranks. Checked the codes.....pulled CODE 82. Any thoughts?
with codes out of the way, i would try to narrow down the problem by checking for spark, then fuel pressure.
There is no spark, and fuel at the fuel rail. I had a brand new ignition coil lying around and it isn't creating spark when I do a spark plug test off of it. I'll check back in the morning, not really sure what to do next though.
