1995 f-350 7.3 diesel a/c bracket removal
Old 03-07-2017, 09:03 PM
Frankhe's Avatar
Frankhe
Frankhe is offline
Unhappy 1995 f-350 7.3 diesel a/c bracket removal
I need to remove the a/c bracket on my 1995 f-350 7.3 turbo diesel to replace a fuel return line. Will, or can someone, please tell me how many bolts hold this thing in place. I've already moved the a/c compressor out of the way, I've moved the power steering pump and I've removed 3 bolts already from the bracket itself. I still cannot jar the bracket loose. where are the other bolts holding this thing in place? If there is a picture of the bracket with the bolt locations, I would sure appreciate seeing it. Thank you kindly.
Do I sound frustrated?
Old 03-08-2017, 12:05 AM
_Trekker's Avatar
_Trekker
_Trekker is offline
I tried looking it up in ProDemand for you but couldn't find anything about it. If you look you should be able to see all the bolts, 7.3l engines don't really hide anything, pretty simple if you just look.
Old 03-08-2017, 04:57 AM
Red97350's Avatar
Red97350
Red97350 is offline
Take a look at this:
https://www.ford-trucks.com/forums/9...t-removal.html
Hope this helps.
Red
Old 03-08-2017, 09:40 PM
Frankhe's Avatar
Frankhe
Frankhe is offline
Hope this helps.
Red
Thank you for your help Red. I looked at that thread previously and it didn't help much since I only found 3 bolts holding the bracket and it looks like those arrows are pointing to the holes of the ones I removed. There must be at least one or two more bolts holding up that bracket somewhere. I will look again on Friday or Saturday and see if I can find more bolts. Being a Handyman doesn't leave me much time to work on my 3 trucks. The customer comes first because they pay the bills. That is unless my other trucks start to give me problems also. In that case, the trucks take priority. They are my transportation to the customer, but I digress. Thanks again.
Old 03-08-2017, 09:42 PM
Frankhe's Avatar
Frankhe
Frankhe is offline
Thank you Trekker, I will look again on Friday or Saturday when I have more time. Thanks for the encouragement.
Old 04-19-2017, 03:45 PM
Sean Reinold's Avatar
Sean Reinold
Sean Reinold is offline
hi did you ever figure out how to get the bracket off as I can only see two bolts. Any diagram would be much appreciated!
Old 04-19-2017, 08:49 PM
MR KROGOTH's Avatar
MR KROGOTH
MR KROGOTH is offline
Looks to be four bolts in total.
jejenkins417
05-12-2022 08:21 PM
Mustangking1
06-30-2014 07:07 PM
Wyokaboy
12-15-2007 10:59 PM
gagnonconsulting
1999 to 2016 Super Duty
07-20-2007 04:15 PM
hydrology_joe
1983 - 2012 Ranger & B-Series
01-09-2006 08:37 PM
Quick Reply: 1995 f-350 7.3 diesel a/c bracket removal
