Have a 99 Superduty , standard cab that has lost both nerf bars due to rocker panel rust. I am searching for a Frame mounted step or bar to replace these.Has anyone found steps or bars that are frame mounted? Or is custom fabrication my next move...
I would guess that frame mounted steps won't flex with the body and may rub/break, so you probably won't find any online. Most likely have to build your own.
