My brakes suck... there is something WRONG!
Thread hijacks and side trips are a given, but this has the chance to go sideways fast, so lets please stop discussing any social niceties or lack there-of and go back to discussing brakes please.
Apoc, hook up with someone who has AE and follow the procedure I have outlined in the brake flush thread I posted (you know where to find the link). Pay attention to the section outlining what to do if you think you have air in the HCU. You will need to use AE or any other tool giving you access to the ABS Hydraulic Control Unit to properly bleed the HCU.
Stewart
Stewart
on
Hope you find the problem. You know if you had a 7.3L you wouldn't have this problem
Did you check to make sure one of your calipers isn't stuck? Happens...even on new ones
Sorry Apoc-I'm on Excursion #3. The brakes sucked on every one of them. The 2001 was the worst. The 04 and 05 have been respectable but if you're a speedy guy, stopping can be exciting--especially when you don't. I share your frustration with the brakes but I think the only way to make a significant after market change is to replace entire braking system with high performance system. You can improve stopping power but then you can't stop the money going out of our bank account...every X owner's achilles heel!
In before Apoc posts some stupid, meaningless Memes to further derail his own thread.
Seriously though, start with the basics and re-bleed the system. Perhaps you screwed up and got air into the system when you replaced everything. If you have access to a decent air compressor, Harbor Freight makes an awesome bleeder for under $30 that will allow you to do them by yourself. Perhaps check the lines where they meet the calipers and make sure everything is tight.
When I flushed out my brakes and bled them, it made a huge difference in pedal-feel and overall stopping confidence.
See, that's what I was expecting! Twitch and I bled the HELL out of my brakes and NOTHING changed. There is no way in hell that there is air in the lines, and even when we bled them no air ever came out. The fluid looked good we bled out as well so I don't think moisture was an issue either.
I've only driven it once since then and it was 11 last night when a fairweather friend called to have me come pull his girlfriend out of a ditch, tow them to a parking lot and change their tire... only for him to just have it towed (for free with his insurance) when the other tire was blown as well (THAT WAS AN OPTION THE WHOLE TIME?!?!?). He called and Wendy and I were there within 8 minutes and were hooking up the tow rope. Damn my wife sure can drive my truck well
A new MC is cheap, $52 for a Centric brand unit. A booster is a bit more... would certainly try previously described methods in this thread for further testing.
How exactly did you bleed the Ex? The lines to the rear are very long and if you did it by 'hand' (foot rather?) you might have missed something. That's why a good bleed tool is so important on an Excursion because it can quickly pull fluid. Speaking of fluid, how is the reservoir? Is it full or are you missing some fluid?
I'd start by draining the reservoir and refilling with fresh fluid, and then get a good bleed tool and bleed the brakes again PR, DR, PF, DF. Make sure you keep an eye on the reservoir so it doesn't go dry.
Start with the basics before you go throwing money at it.
Pedal traveling too far has always been a classic master cylinder problem. I had one go out on my first V-10 and it was exactly as you describe. In for a penny, in for a pound-might as well do the booster while you are at it. I've never had a booster go bad ever so I can't speak to it's symptoms but these are old trucks and seals deteriorate. I usually try to replace anything reasonable when I do a repair job like if I replace a radiator hose and the others haven't been replaced, I just do them all.
#29
#30
