Here is a Retaining / Snap Ring Suggestion
I thought I would share this with you guys, in case you have to ever remove or install larger retaining / snap rings.
I was having a problem getting that medium sized snap ring of the hub assembly, its pretty thick too.
After purchasing multiple snap ring pliers, I finally went to Harbor Freight and bought a pair of 11" Long Needle Nose Pliers for $3.99.
Then I took the tip of the pliers to my bench grinder and made the tips small enough to get into the snap ring holes.
Before conversion:
After Conversion:
I just thought I would share an idea.
Thanks - Preston
Before conversion:
After Conversion:
Thanks - Preston
Haha Chris!! No Michelobs this time. I was dealing with the running gear, I didn't want to make any mistakes.
I just used this set on my 03 F350 and I didn't have any problems with the snap rings.
11 Piece Snap Ring Pliers Set
But I didn't have that kit available to me.
I might invest in that though
Please specify a certain year to get a base for the term "newer".
My previous 2004 6oh I never had to remove that snap ring, but I have heard that the ring is harder than the 2004's and older. Whether that is true or not, is subjective to the owner I guess.
Once ground down the tips of the pliers it worked great, and easy.
This is the exact one I use for the application described in this thread:
As a Ford dealer tech who has had more than his share of these apart, I can vouch for these pliers NEVER slipping thus far. Unlike my Snap-On one that has worn the tips down crooked, making it dangerous to use.
I don't understand why everyone is having such a hard time with the snap ring removal? It's only behind the hub face a few inches and the hub it self is large enough to get even short snap pliers in there. I have an old set of standard length craftsmen snap ring pliers that are a little worn out and I've removed the Ford snap rings a bunch of times with zero issues, and the tips on mine are bent and filed shorter
The coil sprung, wider track 2005 and up Super Duties have front hub snap rings that are much more difficult to engage, as they sit in a different style and diameter of hub, engaging a different style and diameter of stub axle. There isn't nearly the open space surrounding the stub axle to work with within the hub collar. It is completely different set up in that regard than the preceding year.
