Gas tank readings incorrect
Old 08-30-2003, 11:55 AM
Lobo33's Avatar
Lobo33
Lobo33 is offline
I have a 1976 Motor home with a main an auxillary tank. When the tanks are full the guages read 1/2 tank. I just replaced the main tank as it had a leak. I checked all the wiring and connections, but I still get only half the reading I should get. What is the problem.
Old 08-30-2003, 12:57 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
The sending unit or the grounding of the system.
This has been discussed in-depth.
For your reading pleasure. go to the message board search feature and type in : *Fuel Sending unit*
Make sure the forum you are searching is this one.
forager
07-29-2014 11:05 AM
xfillxupx
08-12-2011 10:20 PM
Nighteyez
12-29-2006 03:19 PM
Ifweda
1999 to 2016 Super Duty
16
08-07-2005 02:51 PM
Rbuller24
15
06-11-2003 06:29 PM
Quick Reply: Gas tank readings incorrect
