92 f150, 5.8 auto, trans goes in and out of drive on highway
Old 03-05-2017, 11:06 PM
oneandgone's Avatar
oneandgone
oneandgone is offline
Question 92 f150, 5.8 auto, trans goes in and out of drive on highway
It's been having this issue for a while, but it is getting unbearable. If you stand on it, it shifts through all gears fine. If you run 75 if acts fine.
If you run a constant speed between say 40 and 60 it feels like it drops from drive to neutral, back to drive, back to neutral, back to drive, over and over. If you don't lift off the gas pedal it bangs back into drive fairly violently.
It's been suggested to check and replace vacuum lines, which I'll be starting on tomorrow time permitting. The TPS has also been suggested as a culprit.
I figure that others have had to have had this issue on here, so maybe someone can help. In the meantime I'll be searching for the answer on here in old posts. Thanks in advance for any help or input.
Old 03-05-2017, 11:14 PM
Jim40216's Avatar
Jim40216
Jim40216 is offline
sensor
its the sensor your shifter goes trough on the side of the tranny. had the same prob. changed it and it fixed the prob
Old 03-05-2017, 11:18 PM
oneandgone's Avatar
oneandgone
Thanks for the info, I'll look into that. Do you remember what it was called or about what it cost?
Old 03-05-2017, 11:33 PM
_Trekker's Avatar
_Trekker
_Trekker is offline
First things first make sure your trans oil level is correct, that will make it fall out of gear
Old 03-05-2017, 11:47 PM
Jim40216's Avatar
Jim40216
Jim40216 is offline
sensor
The TRS and neutral safety switch are one and the same part. You can't replace just one.
The TRS is your problem. As it starts to wear out the internal resistance grows. The PCM can misinterpret this as you moving the shift handle to N. Since it thinks that is what you did, it obliges by shifting the trans to N.
Replace the TRS and you should be fine.
(transmission range sensor)
Old 03-05-2017, 11:48 PM
Jim40216's Avatar
Jim40216
Jim40216 is offline
seems like it was about 50$
Old 03-06-2017, 09:07 AM
oneandgone's Avatar
oneandgone
Thanks again, I'm going to pick one up and give it a go. Think I found one for as little as $45.
Yes sir, already did that. Fluid and filter change needed done anyway so I took care of that as a starting point.
Old 03-06-2017, 06:42 PM
oneandgone's Avatar
oneandgone
Jim, I'm trying not to get too excited yet, but I think that fixed it. Thanks!!
Old 03-07-2017, 10:09 AM
Jim40216's Avatar
Jim40216
Jim40216 is offline
great!
anytime 45$ fixes a tranny, its a good day!
Talyn
09-30-2012 11:15 AM
rb8612
27
04-10-2011 08:10 PM
danimal
02-07-2006 11:33 AM
splice
06-03-2000 06:39 PM
Quick Reply: 92 f150, 5.8 auto, trans goes in and out of drive on highway
